I have installed Comfigurator V3.2.1.0. I am trying to setup SMS messaging, on the dropdown list for phone number 1 under phone type i only have NONE, VOICE, PAGER and CMS. in the manual there are other options including SMS which I need. Do i have the wrong version of Comfigurator?
To send SMS Messages you must have the UCM/GSM module.
You need to tell Comfigutor that you have a UCM/GSM by going to the Modules Tab on the top left of Comfigurator
Add UCM and select UCM/GSM with the correct ID
After you have done this then you will be able to select SMS as a phone type
