Search by username
CWM
 Moderated by: adlim
 New Topic   Reply   Print
salizam
Status:  Offline
 Posted: Tuesday May 8th, 2007 07:04 am
 Quote  Reply
mine is a firmware entry ver 5.054 comfort cp9000 control panel. other then the CWS itself, what do i need to install CWM on the system, and how much does it cost. ist available in msia, if not where can i buy it. really need it ASAP. Thanks
adlim
Status:  Offline
 Posted: Tuesday May 8th, 2007 07:19 am
 Quote  Reply
Entry does not support the CWM. You will require a firmware upgrade as well. Please approach your installer on its availability.
 Current time is 01:52 pm
