| Author | Post |
akai Member
| Posts: | 2 |
| Status: |
Posted: Thursday Jan 31st, 2008 02:11 am |
IP before 10.0.0.16
IP new 192.168.0.10
I already change the new IP address using http://10.0.0.16/admin.htm. (Comfort Web Module Administration). In menu display I chose Module Setup. In the IP address and Net mask, I change it with the new IP address 192.168.0.10, Net mask 255.255.255.0, Port 80, and Pass-through port 10001.
Internet Connection I chose LAN connection. In LAN connection I include Gateway IP : 192.168.0.1 ( my router IP address ) Name Server 1 IP : 202.133.0.188, Name Server 2 IP : 202.133.1.5, when finish this section CWM going to reset, after CWM reset finish I check the IP address already change to 192.168.0.10.
When I go to test http://192.168.0.10/ the browse is error 404.
When I go to ftp://192.168.0.10/ is can go in. I already check index.htm file is inside ftp.
regard
akai
leonchue Administrator
| Posts: | 19 |
| Status: |
Posted: Thursday Jan 31st, 2008 07:13 am |
Is CWM working with 10.0.0.16 before the IP change?
If yes, do a check from http://192.168.0.10/admin.htm (if you are able to access the page), to see if the settings are correct?
If all settings are correct, do a power reset on the CWM (ie. switch off the power adapter. After a few seconds, switch it on again). Check if it works this time.
If still not working, then do a cross-cable between your PC and CWM. That will take away network related problems.
1) Power off CWM.
2) Connect a network cross-cable between your PC and CWM.
3) Power on CWM.
4) Access http://192.168.0.10 (your pc should be in the same subnet, ie. having a different IP address but same network mask)
Hope this helps.
akai Member
| Posts: | 2 |
| Status: |
Posted: Friday Feb 1st, 2008 06:18 am |
hai...
I already use this setting before this, but it still same problem.
Now my connection already in cross cable betwen touchscreen computer and CWM.
| Posts: | 19 |
| Status: |
Posted: Friday Feb 1st, 2008 06:49 am |
I don't understand what you mean by that. I will contact you privately to help you out.
 Current time is 01:34 pm | |
