Comfort Automation/ Security System Forums > Third Party (interfacing to Comfort) > Remote Controls > How to Learn Comfort IR Codes into a Universal Learning Remote
 Rating:  Rating
 Posted: Thursday Dec 2nd, 2010 04:55 am
If you would like to use a Universal Learning Remote Control like Pronto (sadly discontinued), Harmony  or others to learn the Comfort IR codes so that it can be used to control Comfort via IR Responses, you will have to  program Comfigurator to send the IR codes from a Comfort Output with a IR transmitter pointing to the Universal Remote Control
The 128 Comfort IR  codes 0 to 127 are in the IR Codes Library in Comfigurator
Go to Configuration > IR Transmit Codes. Select Device as Cytech IR (Comfort). The Operation drop down menu has 128 IR codes names Key000 to Key127.
These keys correspond to the Comfort IR Received Codes 000 to 127.
The file attached ComfortIRcodes.cclx has 32 IR codes programmmed for convenience
To send the IR codes to any output, use WizComfort, and set the file to the attached ComfortIRcodes.cclx then go to Control and the IR Tab
You will see the list of Comfort IR codes
Send each of these codes to any Output by selecting the Output number on the bottom right
This allows all IR codes to be sent to any Output without programming Responses
Attachment: ComfortIRCodes.zip (Downloaded 27 times)
 Current time is 01:46 pm
