Download firmware from http://www.cytech.biz/upgrades.html
UCM 5.159 (9 January 2008)
- PS00 or PS01 does not appear if not logged in - suits RAKO. CWM will still see PS00/PS01 if not logged in
- Fixed BUG DP command does not work when SW8-H shunt is not inserted
- Maximum UCM send RS232 message size increased from 120 to 200 characters
- Fixed - if message from PC is not terminated by message is not terminated by <CR>, the next message is not accepted and NA is returned
- Note: If U2 and U3 master/Copy shunt J4 position is changed, UCM power must be removed and switched on again, otherwise the U2 and U3 EEPROMs cannot be accessed
UCM 5.156
- TC command to copy all characters in Rs232 to Rs485.
- Fixed BUG Flow control did not work
- Improved TM01 operation not to miss characters in either diirection, so no invalid string appears in Bus Monitor
- Fixed bugs UCM/IR learning gives UBF0 after CI01.
- Fixed BUG from 5.120 EEPROM write to U2 as COPY does not work
- Accept "UB" and "UD" if not logged in, so firmware upgrade of Comfort can work without login
- Allow UB01 at all times when programming firmware so previous failed firmware download can recover Version
UCM 5.147 (Flash) 16 April 2007
- Flash Firmware download is supported
UCM 5.92 (5 Oct 2005) Last OTP
- Implemented KL message for keypad LEDS status
- Implemented K? Command to request for keypad led status
- Implemented v?, v! Commands
- Implemented VS commands for download of Comfort II vocab
- Implemented Download of KP data from Comfigurator 2.0 and download of KP text to new KP04
- Can be used to download 32 bytes per line for Comfort II
