Posted: Thursday Dec 30th, 2010 09:22 am |
Whats the latest firmware version for the Zwave UCM?
I went to check on the website but no Zwave firmware downloads there either (unlike with other UCM types)!
Posted: Friday Dec 31st, 2010 04:38 am |
Posted: Wednesday Sep 12th, 2012 10:58 am |
Howser
slychiu wrote:
There is now a Firmware History subforum for UCM/Zwave with links to the firmware upgrade
I cannot seem to find the link. I have a UCM/Zwave that has Zwave 5.157 written on it. I am trying to ascertain which UCM/Zwave (1,2 or 3) it is.
Posted: Wednesday Sep 12th, 2012 11:03 am |
Posted: Wednesday Sep 12th, 2012 11:23 am |
Howser
I saw those, I thought there were detailed version histories I missed.
Can you help?
Posted: Wednesday Sep 12th, 2012 11:41 am |
- Zwave 1 did not have an EEPROM in the U2 socket and could not use the Zwave Configurator. It can send 1 way Zwave commands
- Zwave2 has a U4 EEPROM plugged into the socket, and uses the Zwave Configurator. It can send 1 way commands. It starts from Zwave 5.180 firmware
- Zwave3 is able to send and receive Zwave commands. Firmware version 6 is required. Also the zwave module must be loaded with the "Bridge Controller" function which can be seen in the screenshot below
The firmware can be upgraded to the latest but the important thing to check is whether there is an EEPROM in the U2 socket, and if there is check for Bridge Controller function
Posted: Wednesday Sep 12th, 2012 01:33 pm |
Howser
So this means I just bought a Zwave1?Attachment: IMG_0406.JPG (Downloaded 37 times)
Posted: Thursday Sep 13th, 2012 01:52 am |
Can you return it to the distributor and ask for an exchange?
Posted: Thursday Sep 13th, 2012 03:30 am |
Howser
I will speak to the distributor today. Last edited on Thursday Sep 13th, 2012 03:30 am by Howser
Posted: Wednesday Sep 26th, 2012 09:23 pm |
Howser
Got the replacement UCM today. When I try to upgrade firmware (via Comfort BUS) to 6.024, I get the error "Firmware upgrade encounted errors"
I am using Comfort II Ultra (6.028) and Configurator 3.5.6, I have upgraded other UCMs before (Cbus & GSM) without any issues.
Posted: Thursday Sep 27th, 2012 02:01 am |
what is the firmware version for the UCM/Zwave?
Only Version 6 can be upgraded by Bus
Posted: Thursday Sep 27th, 2012 03:49 am |
Howser
It is version 6.
Posted: Thursday Sep 27th, 2012 03:51 am |
Sometimes the upgrade may fail You can try again or use the UCM Programing cable
Posted: Thursday Sep 27th, 2012 04:26 am |
Posted: Thursday Sep 27th, 2012 04:51 am |
- What was the original UCM/Zwave firmware,
- is the UCM/Zwave still working on its original firmware?
- Did you try the firmware upgrade by programming cable?
Posted: Thursday Sep 27th, 2012 07:13 am |
Howser
I tried the programming cable and got the same result.
Version 6.019
After firmware failures, it shows the version as 6.000. It does not work, getting Timeouts and No Response Errors. It did the same thing with version 6.019 hence why I tried upgrading.
Yes
Posted: Thursday Sep 27th, 2012 07:34 am |
17th Post |
Can you show the Monitor I/O display when trying the Programming Cable upgrade please
Posted: Thursday Sep 27th, 2012 07:37 pm |
18th Post |
Howser
This is what I had originally...
> UB01010E
< RS11
> UB01010E
< RS11 |
I tried the update again to get the screenshot for you and it went through successfully
Posted: Friday Sep 28th, 2012 02:04 am |
19th Post |
I think this could be because of UCM firmware. which version are you using?
Posted: Friday Sep 28th, 2012 02:33 am |
20th Post |
Current time is 11:09 am | Page: 1 2 |
