Fibaro Door / Window Sensor
 Posted: Monday Mar 11th, 2013 10:32 am
Vangelis
Has anyone played with this new hardware yet in conjunction with interfacing to Comfort??
I already have a Z-Wave UCM and was wondering how difficult they are to work with regarding the commissioning of the sensor, as all the documentation is aligned to Fibaro Home Centre 2.
How do the updates to sensor work if not using HC2??
Thoughts?
Vangelis...
 Posted: Thursday Mar 14th, 2013 08:50 am
I'm using both the 2x1.5KW and dimmer relays with my UCM\Zwave3 and so far they are working fine.
 Posted: Thursday Mar 14th, 2013 09:32 am
I heard that the Fibaro switches need to be pressed 3 times in order to add into the Zwave network via the controller. Is that correct?
 Posted: Thursday Mar 14th, 2013 10:25 am
True if you are using a bi-stable switch. My old ACT switches needed wasn't it two state changes to do the same.
There is a small button on the unit that performs inclusion/exclusion too.
J
 Current time is 02:05 pm
