Strange thing
 Posted: Monday Aug 3rd, 2020 01:46 pm
Ian
I have a Comfort II with a Z-wave board. I know Z-wave is being phased out - but when its working it works well for me.My Primary Z-wave controller is HomeSeer software. Comfort is a secondary controller.
I have over 40 Z-wave devices some of which are virtual devices created from Comfort.I recently added a couple of new physical devices using the primary controller. They appear and function as they should.I did a 'Learn' in Comfort so I could uses one of the devices in a Response.The 2 new devices appeared following the LearnHowever - when I go to try and program a response the Z-wave action only shows the Basic Get Command, the Set Command is not available.Not only is not available for the new devices it has disappeared for all devices!The devices still work and I can control them using the ON and Off switches in the Z-wave mapping window.If I go back and load an earlier CCLX everything is back to how it should be!I have tried 're-learning' but each time the same thing happens.Any ideas or suggestions are welcome.
 Posted: Tuesday Aug 4th, 2020 07:37 am
Swiss-Toni
Have you tried an earlier version of comfigurator
 Posted: Tuesday Aug 4th, 2020 10:56 am
Ian
Swiss-Toni wrote: Have you tried an earlier version of comfigurator
Worth a try - I'll give it a go :-)
 Posted: Tuesday Aug 4th, 2020 11:47 am
Ian
I tried 3.13.3 and 3.13.12 but it was the same.
I also tried manually editing a response instead of using the wizard. It edited OK but the response did not execute.
Any more ideas are welcome.
 Posted: Thursday Aug 6th, 2020 04:36 pm
Ian
@slychui Can you suggest how I might debug this?
 Current time is 09:07 am
