ComfortClient
 Moderated by: juwi_uk, Ingo
 Posted: Sunday May 3rd, 2009 04:55 pm
Advanced Member
This thread is for the new 1.0.18.1 version released today.
I have fixed the bug in 1.0.17.4 that could lead to Floorplans being clipped on save if the window had been scrolled.
New for this release is the ability to hide/show the Keypad and Control panels.  This is useful if you are running on lower resolution screens/panels where you want to only use features of the panel at specific times.
Bug Fixes
  • Saving a Floorplan when the visible area is scrolled (top left is now not 0,0)  would store the objects at the scrolled state.  Scroll state is now reset to 0,0 before saving.
  • Right-Click menu on Floorplan (not Objects) was incorrectly disabled in a recent build.
New Features
  • Keypad and Control panels can now be hidden if required to maximise screen use and when used on devices with lower screen resolutions.
Download from link below:
<link removed by JUWI_UK>
Attachment: Capture.JPG (Downloaded 34 times)
 Posted: Sunday May 3rd, 2009 10:27 pm
Advanced Member
I've tweaked the concept (top right) now so that they are buttons.  Looks a bit nicer than checkboxes.
Will be in 1.0.18.2.
Attachment: Capture.JPG (Downloaded 31 times)
 Posted: Sunday May 3rd, 2009 11:24 pm
Advanced Member
All,
I've posted a revision today after Ingo found a couple of minor issues with the sizing of his floorplan and the scroll bars.
Bug Fixes
  • Fixed issue with horizontal scrollbar missing.  It was enabled but hidden behind the status bar.
  • Status bar now stretches/shrinks correctly.
New Features
  • Keypad and Control panel show/hide method now changed to buttons from check boxes.
Sorry for 2 postings on 1 day but thought you'd like the fix.
 Posted: Monday May 4th, 2009 05:35 pm
Advanced Member
Hi All,
A bit more work on this today to get a 1.0.18.3 version.
Bug Fixes
  • Corrected issue with X10 feedback not shown on Control Menu tree.
New Features
  • Increased amount of feedback onto status bar & convert to Dec from Hex.
  • Timestamp [hh:mm:ss] added to Monitor window entries.
  • It is now possible to TAB to next field on the Connection Tab using the enter key.
Download and use if you need.  Note you only need to overwrite the "ComfortClient.exe"
and "ComfortClient.chm" if you are upgrading.
 Current time is 05:53 am
