Comfort Home Automation/ Security System Forums > Software Applications > ComfortClient > Problem with remote connection with comfort client
 Moderated by: juwi_uk, Ingo
 Posted: Thursday Feb 9th, 2012 11:51 am
koutsogiannis
I try to connect remotely to the comfort with client. The error message I get is that the photo upload. The version I have is the past. In earlier versions remotely connect without any problems. The Wizards Comfort connect normally.
Attachment: client problem connection111.jpg (Downloaded 44 times)
 Posted: Thursday Feb 9th, 2012 01:13 pm
Advanced Member
Does it work on the local LAN?
Perhaps when you try to connect remotely you forgot to open UDP port 65535 on your router. That is the port that the Tibbo Module uses for connection information.
Newer Client versions check the Tibbo Module before it makes a connection.
Regards,
 Posted: Thursday Feb 9th, 2012 05:04 pm
koutsogiannis
I opened the door, and 65535, but not connect. Version 1.20.2.35 is linked properly. What could be the problem?
 Posted: Thursday Feb 9th, 2012 06:16 pm
ninotorres
I have the same problem.
 Posted: Thursday Feb 9th, 2012 07:12 pm
Advanced Member
So as Ingo says you need whatever TCP port you are connecting on (1001 typically) and UDP port 65535.
The timeout for the UDP response is hardcoded at 3 seconds so it looks like you didnt get a reponse within that time. Does it repeatedly fail or just sometimes?
I'll make the Tibbo checking an option in the next build so you can turn off.
 Posted: Thursday Feb 9th, 2012 08:11 pm
Advanced Member
Replace the current ComfortClient.exe with this patched version where I've disabled the Tibbo checking and let me know if it works.
http://www.futurehomesoftware.co.uk/releases/ComfortClient-3.1.2.21-NoTibboCheck.zip
 Posted: Thursday Feb 9th, 2012 08:42 pm
koutsogiannis
It works ok. Τhank you very much Julian.
 Posted: Thursday Feb 9th, 2012 08:45 pm
Advanced Member
So it's either UDP port 65535 being blocked then or the link being slow and you not getting a response back from the Tibbo within 3 seconds. I'll make more configurable next release for these scenarios.
J
 Posted: Sunday Feb 12th, 2012 09:55 am
ninotorres
The patched version worked perfectly.
And yes I don't have the mentioned UDP port opened, so that's why it fails.
My question now is, what does that checking for Tibo module adds? I was fine with only one well defined port opened in my firewall.
Thanks,
Nino
 Posted: Sunday Feb 12th, 2012 03:45 pm
Advanced Member
I added this functionality because the tibbo module can only accept one connection at a time. So via this tibbo management port i can check if the ucm is already connected to something (eg comfigurator, iphone app, Wizcomfort etc) and warn the user appropriately either to gracefully concede to the existing connection or force it to close so you can grab it! I found this useful for eth02 modules though less important with later Eth02 ones as they now auto disconnect on logoff.
J
 Posted: Monday Feb 13th, 2012 10:17 am
ninotorres
Ok, I understand that need. And I want it too.
But my feedback is that checking should be made optional in the ComfortClient.
In my current implementation I would disable it for sure.
Thanks,
Nino Torres
 Current time is 04:50 am
