Value transform in Comfort Client
 Moderated by: juwi_uk, Ingo
 Posted: Monday Sep 17th, 2012 02:42 pm
BernardW
I'm using a counter to measure in 6 min chunks. I was hoping to use the value transform to /10 and display as hours. Selecting the transform doesn't seem to do anything. What am I missing?
 Posted: Monday Sep 17th, 2012 09:26 pm
Hi Bernard,
You didn't say which version you are using so I'll assume the latest.
You are correct though that the Value Transform doesn't work for type COUNTER. Apologies that is a bug.
Also it is enabled for SENSORS on gauge objects which is also wrong.
To be honest this feature was mainly added for plugins rather than Comfort objects which max out at 255. I didn't really envisage that you'd want to divide 255 by something but hey I was wrong.
OK so I've fixed in the next release 3.1.5.x. Currently 3.1.5.1 has this fixed. If you want to test out this build then send me a PM and I'll send you the link to the beta (which is stable).
Other fixes in 3.1.5.1 are BTW:
Bug Fixes/Changes
• Scroll bars now correctly appear in FloorplanEditor when the editor panel is smaller than the size of the floorplan.
• Value Transforms were incorrectly enabled for SENSORS when object type is Circular or Linear Gauge.
• Value Transforms did not work correctly for COUNTERS for object types Label, Circular and Linear Gauges.
New Features
• Holding CTRL key down during ComfortClient application launch disables plugin load. The “-X” command line switch also does the same.
• Holding SHIFT key down during ComfortClient application launch disables AutoConnect (if otherwise normally set to auto connect). The “-A” command line switch also does the same.
• Start-up time now displayed in monitor and log files.
• New right-click menu on floorplan tab:
o Clear Tab Log
 Current time is 02:21 am
