Door station Distortion
 Posted: Sunday Jan 15th, 2012 04:49 pm
WMADKOUR
I got a weird problem at two sites, I connect the door station by Cat5e cable to comfort v5.212, the sound between KP & DP is great with the back cover loose, once we fix it and screw it, high Distortion generate and we can't hear any thing, we made sure that the wire is not pushing anything but still got the same result. Appreciate any suggestion
 Posted: Monday Jan 16th, 2012 08:37 am
Which door station are you using DP03 or DS01 or DS02?
Make sure you use the default tuning parameters
Open a new file with default template so that the default tuning parameters are loaded If you use an older file tyhe tuning parameters may not be defaults
If you use DS01 or DS02 there are volume controls for mic and speaker and those should be adjusted lower so thereis no howling sound
 Posted: Monday Jan 16th, 2012 11:56 am
WMADKOUR
I'm using DP03, i upload tuning parameter only but with the same status,
the problem occure only when i closed the back cover of the DP03  !!!!
 Posted: Monday Jan 16th, 2012 12:15 pm
For DP03 you should not try to do any tuning of the internal volume control inside the DP03  or in the Comfort PCB MIC and Voice trimmers if they are prsent
If you have done so, reduce the gain until the howling disappears.
In DP03 and KP04 there are some sponge material to help in accoustic isolation
These should not be removed otherwise howling will result
 Current time is 04:55 am
