KP06 stopped working
 Posted: Wednesday Feb 2nd, 2022 03:09 pm
Ian
I have a KP06A on my system, Comfort II Ultra. Today I got a beeping from another keypad and Communication Failure' showing on the other keypad, a KP06, The KP06A has a blank screen and the keys are unresponsive. It is illuminated.Any ideas?
 Posted: Thursday Feb 3rd, 2022 12:32 am
Did you try to power off the KP06 and on again? What is the serial number?
 Posted: Thursday Feb 3rd, 2022 07:43 am
Ian
Thanks for getting back to me.
I did disconnect, reconnect and then reset the system. I now have messages on the LCD screen but no sound and the keypad functions intermittently. I have checked the wiring and it all appears intact. The sticker on the metal frame is C092843, is that the serial number.
 Posted: Thursday Feb 3rd, 2022 11:40 am
Yes the keypad is from 2017. thanks.
Can you try to upgrade the firmware on the KP06?
do you still get communications failure for the keypad?
 Posted: Sunday Feb 6th, 2022 04:43 pm
Ian
The firmware is up to date. I have taken it out a few times and put it back in, at the moment it has started working again. However, the sound is both quiet and slightly distorted. The screen and the keypad are both working. This is a KP06A. I have a KP06. Can I swap the screen/speaker module to see if the problem is the module or the base board?
 Posted: Monday Feb 7th, 2022 01:24 am
Yes please swap
 Posted: Monday Feb 7th, 2022 04:47 pm
Ian
Swapping the lcd/speaker module identifies that is the problem. Is it possible to purchase a replacement of just the module?
 Posted: Tuesday Feb 8th, 2022 12:43 am
Please contact Laser to check if they have this part
 Posted: Thursday Feb 10th, 2022 04:37 pm
Ian
Laser suggested I contact you !!
 Posted: Friday Feb 11th, 2022 12:15 am
Can you send an email to support@cytech.biz plerase
 Posted: Friday Feb 11th, 2022 06:36 am
Ian
Done. :-)
 Posted: Tuesday Jan 16th, 2024 12:10 pm
Ian
I ordered a replacement, I asked for the module that contained the speaker for a KP06. I received the speaker in the attached photo. As can be seen the speaker is larger than the grill on them module. Before I get back in touch with the supplier, can anybody confirm that this is not the speaker that fits inside the module?
Attachment: Speaker.jpg (Downloaded 7 times)
 Posted: Wednesday Jan 17th, 2024 12:59 am
13th Post
That is not the correct speaker for KP06A. You need the plug in module with lcd and speaker part number XA03-0015.  The actual speaker used in KP0^A is a 20mm speaker with wires that you need to solder, and you would need to dismantle the module. so I suggest the complete module replacement
 Posted: Wednesday Jan 17th, 2024 08:56 am
14th Post
Ian
Thank you.
 Current time is 11:24 pm
