Comfort Home Automation/ Security System Forums > Support > Problems & Troubleshooting > UCMs > Alarm becomes unresponsive when RS232 cable is connected
 Posted: Sunday Aug 9th, 2009 08:12 pm
freak69
I have a strange promlem that I hope someone can help me with.
I'm installing my comfort system at the moment and all seems well so far except when it comes to the UCM05.
If I have the UCM05 connected but no serial link to the PC, everything seems to work fine. keypad is responsive, the UCM05 green led blinks very fast (almost too fast to see) and the reg led blinks fairly fast.
So, I go to plug inthe serial cable to the PC. The blinking immediatly slows right down, (green maybe 2 per sec and red maybe 1 every 2 or 3 secs) not just on the UCMo5, but on my UCM CBUS too.
The keypad is now VERY unresponsive and hardly works at all. The configurator software doesnt see the UCM, but I know using putty or hyperterminal that there is occationally data from the comfort system there. (it just doesnt want to reply to a login within a reasonable amount of time).
So, it looks like the act of plugging in the RS232 serial makes the system slow to a crawl and become useless.
Any idea why this would be ?
Paul
UCM05 v5.164
 Posted: Thursday Aug 13th, 2009 02:43 pm
I have not seen this symptom before
Could it be a problem withyour PCI card causing a conflict with the Rs232 port?
Can you try removing the PCI Card or better still try another PC serial port?
 Posted: Thursday Aug 13th, 2009 04:03 pm
freak69
Done that :(
There's an on-board serial and a PCI card with 6 ports. Tried both and no luck. Actually almost all of them are used by other things, so they definitly work.
Wondering if this is a faulty UCM?
Paul
 Posted: Friday Aug 14th, 2009 01:43 am
Please get a replacement from your supplier. We will look at the cause of the problem when we get it back from them
 Posted: Saturday Aug 22nd, 2009 12:16 pm
freak69
Replacement installed and all is working perfectly.
Many thanks
Paul
 Posted: Sunday Aug 23rd, 2009 04:00 am
Please return your old UCM back to the supplier so that we can see what was wrong
 Current time is 12:49 pm
