Comfigurator - migrating from V223 to V328
 Posted: Saturday Aug 6th, 2011 07:32 am
dcrera
I am migrating from V223 to V328.
How can I successfully import my old .ccl into the new version.
Tried the import option and it dropped off all my responses and settings. The only section that seems to have imported correctly is the Gereral Tab.
Is there a conversion process or a utility to convert ?
 Posted: Saturday Aug 6th, 2011 11:58 am
You can read ccl files created by Comfigurator 2 using Comfigurator 3. In Comfigurator 3, do File Open > select Files of type .ccl
This reads the ccl file. save them as .cclx file type
 Posted: Monday Aug 8th, 2011 04:38 am
dcrera
Ok, I used up all my dumb questions for today:D
 Posted: Friday Aug 12th, 2011 03:39 pm
dcrera
I upgraded my firmware on Comfort to 5.218 and my *serial ucm to 6.007
When I try to connect to Comfort i get 'Failed to write to Ucm' using Comfigurator 3.28
If I use the the newer UCM with the serial sister board with ver 6.007 I get connectivity.
What's the buzz ?
PS *the serial ucm works with Comfigurator 2.28
 Posted: Friday Aug 12th, 2011 04:05 pm
Advanced Member
Hi I'm using one of the older UCM/Serial boards (serial connector and jumper onboard) with 6.007 without any problems.  I'm using the latest Comfigurator 3.3.1 though.
I guess you've seen that issue that Ingo found in Comfigurator and serial connections if the "via KT03" box is ticked.
 Posted: Friday Aug 12th, 2011 04:17 pm
dcrera
Please send me the url with reference to KT03
 Posted: Friday Aug 12th, 2011 04:42 pm
dcrera
Loaded Comfig 331
Error ' No response from UCM' using older UCM with ver 6.007
Help I need somebody
 Posted: Friday Aug 12th, 2011 04:58 pm
Advanced Member
See this thread at the bottom:
http://www.comfortforums.com/forum20/2382.html
 Posted: Friday Aug 12th, 2011 05:32 pm
dcrera
Changed to USB and KT03 was unckecked.
Changed back to Serial (no Rs232)
Tried connecting again, same problem 'No response from Ucm'
When back to newer UCM with sister board ver 6 and I get the came error 'No response from Ucm'. Going in circles
 Posted: Saturday Aug 13th, 2011 02:25 am
Check shunt SW8-H should be off (Hardware handshake)
SW8- F and G should also be off
If that still happens uninstall and reinstall Comfigurator
There may be some settings left over from the older Comfigurator
 Posted: Saturday Aug 13th, 2011 08:14 am
dcrera
Uninstalled 331 and cleaned up the registry and reloaded version 328.
The newer UCM with the sister serial board has connectivity with 328.
The older serial UCM has no connectivity with 328.
I need both to work as I want to use the newer UCM with the plugin ethernet module for the Ipad and the older serial UCM for Control4
The older serial UCM works with 223.
Both UCM has firmware 6007
 Posted: Saturday Aug 13th, 2011 08:43 am
can you install 3.3.1 on another PC and check if both UCMs  are working Comfigurator 2 can coexiti with Comfigurator 3 on the same PC but you can only use one of them at a time to comunicate with the UCM because the COM port ncan be used by 1 application at a time
Also connect using Hyperterminal to the  UCM which is having problems see if you can communicate  by seyting the COM port
 Posted: Saturday Aug 13th, 2011 03:40 pm
13th Post
dcrera
New UCM with sister board works on 223, 328 and hyperterminal
Old UCM works with 223 but not on 328
However the hyperterminal on old UCM is extremely slow when typing <C>LI1234
and does not respond. Tried with shunts F &G off and on
 Posted: Saturday Aug 13th, 2011 05:47 pm
14th Post
Advanced Member
Could it have been that your 223 config was set at a different baud rate for the UCM serial; say 4800 and on 328 it is set for 9600?
I guess without checking the jumpers that set the baud rate on the card it's difficult to know.
Just a thought.
 Posted: Sunday Aug 14th, 2011 02:02 am
15th Post
Iif you say the old UCM is extremely slow when typing LI1234 with Hyperterminal that could indicate a problen with it and why it does not work with Comfigurator
It cannot be the wrong baud rate otherwise it would not work at all, unless you set a different baud rate on Hyperterminal? the UCM does not allow diffierent baud rates exceptp for some special firmware versions
Can you send a photo of the old UCM to support@cytech.biz so we can check
 Posted: Sunday Aug 14th, 2011 06:13 am
16th Post
dcrera
Hi Julian,
Which jumper sets the baud rate?
I all instances I used 9600 on HTerm
Thanks for the feeds.
 Posted: Sunday Aug 14th, 2011 08:24 am
17th Post
Advanced Member
Sorry, my mistake, you cant.
J
 Current time is 05:05 am
