Posted: Saturday Nov 12th, 2011 10:40 pm |
lwillerton
Posts: | 221 |
Hi All,
I have been trough a bit of pain with updating the config to the system. Chiu has been brilliant in supporting me to a point where I got the latest system firmware installed.
Configurator 3.3.3
Frimware 6.005
UCM 10 6.002.
Basically the upgrading of a config change works ok sometimes and not other. I have disabled timeout on the DS manager which helped get the system firmware on. For the rest of the time what I have been doing when uploading stops is pressing the reset button on the ETH UCM. However, I have now put the case on and its a pain to do this as I end up triggering the tamper alarm every time I have to hit the reset, check out my other posts for help with tamper alarm :-)
I get no interruption when doing a ping - t of the system so it's on the network.
Now I have been away for around 3 weeks and the iPhone app has connected seemlessly for all this time. However a couple of days ago the app said it was connected, but when I entered my code it did not change to the keypad screen as normal. Also I logged on to the configurator and it would not talk to the system.
I pressed the reset on the ETH UCM without making any changes to comfigurator, iPhone or the network and everything came to life again.
I realise I need to upgrade the ETH UCM to 6008 and intend doing that when I get a chance over the next week.
But has anyone got any ideas on what I can to in order to keep the connection alive without having to keep pressing the reset button. This is just bad as I have triggered the tamper alarm a couple of times late a night, see my other post asking for help on removing the case without triggering the alarm :-)
Cheers
Lee
PS Sorry If I have posted this in 2 different places please remove duplicate if I have.
Cheers
Lee
Posted: Sunday Nov 13th, 2011 12:47 am |
Are you connected to the UCM/Ethernet on the Local LAN or remotely by Internet when you do a write to Comfort? When does the transfer stop? Can you send the Monitor I/O trace when this happens.
Are you sure you need to press the Reset button on the UCM when this happens?
Did you just try to Login again by Comfigurator?
Can you see the UCM using the DS Manager when it happens?
Posted: Sunday Nov 13th, 2011 01:39 am |
lwillerton
Posts: | 221 |
Hi Ident,
iPhone connects via Internet.
Say's connected but when I enter my 4 digiet code it does not change screens
Comfigurator connects via local LAN
Just get "can't connect to UCM".
When I press the reset on the ETH UCM it all starts to works fine again with no additional actions needed.
It has taken 3 weeks for comms to fail when I am just using the iPhone, however when connecting via Comfigurator it seems to crash during my time uploading / making changes within 1 - 4 hours max
if it works it goes through great, if it failes then the UCM monitor says LI*** and when I get the error message "can't connect to UCM" UCM monitor repeats the LI*** message.
I have looked all over the forums and I really don't understand how I can update the ETH UCM. System 6005, ETH 6002. Can you point me to a post that says how its done?
Just wondering if the update might help my connection.
Chiu has connected to my system by teamviewer a while ago when I was trying to get the system firmware updated and could see the error message at the same time DS manager could see the system.
Ping test show system is available when it stops working.
Hope this all make sense if not please tell me what you need as I really want to get to a stable comms so that I don't have to keep opening the system up to press the reset button.
All the best
Lee
Posted: Sunday Nov 13th, 2011 01:53 am |
iPhone login problem when it does not turn green. Is that a common occurence? Ocasionally overf the internet some characters are lost and even though you entered the correct code the iPhone dooes not get the log in reply. I get the same problemn and there may not be much that can be done about it except to try again
Upgrading the UCM/Ethernet firmware is by Direct connection to PC method, see http://www.comfortforums.com/forum4/2283.html
I dont remember if you had a lot of problem with this before due to the disconnection problem. If so I would not advise attempting it yet until the disconection problem has been solved
I recall that we we saying the problem may be in the network, that it causes disconnection for some reason
Have you tried connecting to the UCM/Ethernet direct to the computer using a cross cable? This wiill eliminate the network and we can see if the communications is good
Posted: Sunday Nov 13th, 2011 09:25 am |
lwillerton
Posts: | 221 |
Hi Ident.
Sorry been away for a while so forgot about the xover cable idear. I will pick one up from work tomorrow and give it ago.
Cheers
Lee
Posted: Saturday Nov 19th, 2011 09:42 am |
lwillerton
Posts: | 221 |
Hi Ident
I have tried using an xover cable since last night, unfortunately it failed this morning with the same “no response from UCM†message. Same process seemed to work and pressing the reset on the ETH UCM seemed to clear to problem. This has only happened once so will keep trying to see if it was a one off though.
I will add that a couple of days ago when I was using comfigurater and it stopped working that the iPhone app continued to give feedback on the zone states and I could turn lights on and off. This only happened for a few minutes but in my mind proves comms where still alive.
I took a copy of the log file at the point of failure which you can see below.
Cheers
Lee
Posted: Saturday Nov 19th, 2011 09:43 am |
lwillerton
Posts: | 221 |
> LI****
> UL000003
> V?
> v?
> U?
> u?11
> u?12
> u?13
> u?14
> u?15
> u?16
> u?17
> u?18
< LU02
< DL00000305FF22D7
< V?FE060522200100
< v?05FF23010203FFFF
< U?0A060211
< u?110A0602
< u?120E05DA
< u?13FFFFFF
< u?14FFFFFF
< u?15FFFFFF
< u?16FFFFFF
< u?17FFFFFF
< u?18FFFFFF
> SR01
> DT20111118221029
> DL00000205FFFA
< OK
< DT2011111822102900
< OK
> L00031C010507080302040E11130B17151416101C1B120A0C09001D19181F1C2F
< OK
> DL002709BC700001FF5AFFFF2D1F
< OK
> DL0032020A01C1
< OK
> DL003502055074
< OK
> DL003820101E05070002000308C00123050708FFFFFFFFFFFF14110607000200031CC00656
< OK
> DL005820071CFFFFFFFFFF04000403010012FF05021002100901FFFFFFFFFFFFFF00FFFF23
< OK
> DL007819FFFFFFFFFFFFFFFFFF00FFFF02020408030301040407020D0441
< OK
> DL010820051E3412FF000D3412FF000D0F51122F51120F510D0D51120A221204220D042298
< OK
> DL01281C1224221224220D40621160621140591160593240552D40552D40552D9D
< OK
> DL0180204C001300404C141314A34C010014804C040004804C02000880260A000A80260A21
< OK
> DL01A020300A80261413288026010004803F1430148036080004A23614001480003C701749
< OK
> DL01C02001BCE02E027070170370E02E047C1400053860090330C800073C7017003C280077
< OK
> DL01E020067014000330E47F0A30EC130B307017083CB00406302800043014000B303C00CF
< OK
> DL0200140230701703307097FF1000800000940100000000D3
< OK
> DL021820214202FFFF2E012F01213102FFFF2C012D01225201FFFF32013301235701FFFF04
< OK
> DL02382030013101004300FFFF00000000004800FFFF00000000005600FFFF000000000068
< OK
> DL0258204000FFFF0000000001010101010101010101010101010101010101010101010130
< OK
> DL027820010101010101010101010101010101010101010101010101200900000000000025
< OK
> DL029820000000000000000000000000000000000000000000000000000000000000000046
< OK
> DL02B80800000000000000003E
OK
> DL02D0201805000000000000000000000000000000000000000000000000000000000000F1
< OK
> DL02F0200000000000000000000000000000000000000000000000000000340100000000B9
< OK
> DL068805020001010069
< OK
> DL0694013C29
< OK
> DL069701B4AE
< OK
> DL069902D30389
< OK
> DL069C0200FF5D
< OK
> DL069F01FF5B
< OK
> DL06A20D03030000000A010350000000FCEB
< OK
> DL0709206E00650066006700680069006A006B0079007300FF006D006F00480049004700EB
< OK
> DL072902C21EEE
< OK
> DL07360100C2
< OK
> DL07390106B9
< OK
> DL073B2041510000000000000000000000000000000000000000000000000000000000000C
< OK
> DL075B2000000000000000000000000000000000000000000000000000000000000000007E
< OK
> DL077B01007D
< OK
> DL07800801020000000000006E
< OK
> DL07A0100000000000000000000000000000000049
< OK
> DL07D0201203FF2626FFFFFFFFFFFFFF0104181407FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
< OK
> DL07F016FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71060887
< OK
> DL083612FFFF4343437FFF7F7F7F7F7F7F7F7F7FFF7F76
< OK
> DL085605060308083C48
< OK
> DL0862050A1E051E0541
< OK
> DL0869200107779530966FFFFFFFFF0107595284858FFFFFFFFF0101623855684FFFFFFF3E
< OK
> DL088920FF0101623857942FFFFFFFFF0101158405810FFFFFFFFF00FFFFFFFFFFFFFFFF7A
< OK
> DL08A920FFFF00FFFFFFFFFFFFFFFFFFFF0001623842351FFFFFFFFF00000000000000000E
< OK
> DL08C92000000000000000000000000000000000000000000000000000000000000300000C
< OK
> DL08E9200000000000000000000000000000000000000000000000000000000000000000EF
< OK
> DL0909200000000000000000000000000000000000000000000000000000000000000000CE
< OK
> DL09292000000000000000000000000000000000000000000000005400008A23385B01B069
< OK
> DL09491823535B01FF05003F00FF00454500C523205B01FF2300180159
< OK
> DL0A0820FC860101FCC6010114860601048606013C86010154820601FC82010100A300058B
< OK
> DL0A2820FFA60E05FFA60C05FF860D05FF86090BFC860B0B28860F01FF860101A8820F01F9
< OK
> DL0A48207C8619050C860101FF820101FF860B0B0CA419053C860E05FF860C0500830005FB
< OK
> DL0A6820FC830101FF860101FFA601013C8201010C810101008B000000AB0000FFFFFFFF3E
< OK
> DL0B0020420000000000011601000080010000000080010000000080050000000080010073
< OK
> DL0B202000000080050000000000122501000000121C010000805200000000801221010043
< OK
> DL0B402000001200000000000C000000000012000000000012000000008012000000008041
< OK
> DL0B6020000000000000000000000000000000000000000000000000000000000000004A2B
< OK
> DL0B802001000000174A01000000174A01000000004A010000000000000000000000000045
< OK
> DL0BA020000000000000000000000000000000000000000000000000000000000000000035
< OK
> DL0BC020000000000000000000000000000000000000000000000000000000000000000015
< OK
> DL0BE0200000000000000000000000000000000000000000000000000000000000000000F5
< OK
> DL0C00200000000000000000000000000000000000000000000000000000000000000000D4
< OK
> DL0C20200000000000000000000000000000000000000000000000000000000000000000B4
< OK
> DL0C4020000000000000000000000000000000000000000000000000000000000000000094
< OK
> DL0C6020000000000000000000000000000000000000000000000000000000000000000074
< OK
> DL0D802016BAFFFF02BAFFFF0217BAFF17BAFFFF1719FFFF3DBAFFFF3D19FFFF4519FFFF57
< OK
> DL0DA0202019FFFF101B19FF391B19FF250619FF2506D7FF5D0619FF160619FF0206FFFF54
< OK
> DL0DC020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12C7FFFFC310FFFFC339FFFF17C3FFFFA9
< OK
> DL0DE020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
< OK
> DL0E0020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2
< OK
> DL0E2020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
< OK
> DL0E4020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2
< OK
> DL0E6020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92
< OK
> DL0F8020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71
< OK
> DL0FA020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51
< OK
> DL0FC020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31
< OK
> DL0FE020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11
< OK
> DL100020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
< OK
> DL102020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0
< OK
> DL104020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0
< OK
> DL106020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90
< OK
> DL108020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70
< OK
> DL10A020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
< OK
> DL10C020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30
< OK
> DL10E020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10
< OK
> DL110020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF
< OK
> DL112020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
< OK
> DL114020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
< OK
> DL116020FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F
< OK
> DL11802000000000000000000000000000000000000000000000000000000000000000004F
< OK
> DL11A02000000000000000000000000000000000000000000000000000000000000000002F
< OK
> DL11C02000000000000000000000000000000000000000000000000000000000000000000F
< OK
> DL11E0200000000000000000000000000000000000000000000000000000000000000000EF
< OK
> DL1200200000000000000000000000000000000000000000000000000000000000000000CE
< OK
> DL1220200000000000000000000000000000000000000000000000000000000000000000AE
< OK
> DL12402000000000000000000000000000000000000000000000000000000000000000008E
< OK
> DL12602000000000000000000000000000000000000000000000000000000000000000006E
< OK
> DL12802000000000000000000000000000000000000000000000000000000000000000004E
< OK
> DL12A02000000000000000000000000000000000000000000000000000000000000000002E
< OK
> DL12C02000000000000000000000000000000000000000000000000000000000000000000E
< OK
> DL12E0200000000000000000000000000000000000000000000000000000000000000000EE
< OK
> DL1300200000000000000000000000000000000000000000000000000000000000000000CD
< OK
> DL1320200000000000000000000000000000000000000000000000000000000000000000AD
< OK
> DL13402000000000000000000000000000000000000000000000000000000000000000008D
< OK
> DL13602000000000000000000000000000000000000000000000000000000000000000006D
< OK
> DL13802000000000000000000000000000000000000000000000000000000000000000004D
< OK
> DL13A02000000000000000000000000000000000000000000000000000000000000000002D
< OK
> DL13C0200000000018011801000000000000000000000000000000000000000000000000DB
< OK
> DL13E0200000000000000000000000000000000000000000000000000000000000000000ED
< OK
> DL1400200000000000000000000000000000000000000000000000000000000000000000CC
< OK
> DL1420200000000000000000000000000000000000000000000000000000000000000000AC
< OK
> DL14402000000000000000000000000000000000000000000000000000000000000000008C
< OK
> DL14602000000000000000000000000000000000000000000000000000000000000000006C
< OK
> DL14802000000000000000000000000000000000000000000000000000000000000000004C
< OK
> DL14A02000000000000000000000000000000000000000000000000000000000000000002C
< OK
> DL14C02000000000000000000000000000000000000000000000000000000000000000000C
< OK
> DL14E0200000000000000000000000000000000000000000000000000000000000000000EC
< OK
> DL1500200000000000000000000000000000000000000000000000000000000000000000CB
< OK
> DL1520200000000000000000000000000000000000000000000000000000000000000000AB
< OK
> DL15401E0000000000000000000000000000000000000000000000000000000000008D
< OK
> DL15602000000000000000000000000000000000000000000000000000000000000000006B
< OK
> DL15802000000000000000000000000000000000000000000000000000000000000000004B
< OK
> DL15A02000000000000000000000000000000000000000000000000000000000000000002B
< OK
> DL1620200000000000000000000000000000000000000000000000000000000000000000AA
< OK
> DL16402000000000000000000000000000000000000000000000000000000000000000008A
< OK
> DL16602000000000000000000000000000000000000000000000000000000000000000006A
< OK
> DL16802000000000000000000000000000000000000000000000000000000000000000004A
< OK
> DL16A02000000000000000000000000000000000000000000000000000000000000000002A
< OK
> DL16C02000000000000000000000000000000000000000000000000000000000000000000A
< OK
> DL16E0200000000000000000000000000000000000000000000000000000000000000000EA
< OK
> DL1700200000000000000000000000000000000000000000000000000000000000000000C9
< OK
> DL1720200000000000000000000000000000000000000000000000000000000000000000A9
< OK
> DL174020000000000000000000000000000000000000000000000000000000000000000089
< OK
> DL176020000000000000000000000000000000000000000000000000000000000000000069
< OK
> DL178020000000000000000000000000000000000000000000000000000000000000000049
< OK
> DL17A020000000000000000000000000000000000000000000000000000000000000000029
< OK
> DL17C020000000000000000000000000000000000000000000000000000000000000000009
< OK
> DL17E0200000000000000000000000000000000000000000000000000000000000000000E9
< OK
> DL1800200000000000000000000000000000000000000000000000000000000000000000C8
< OK
> DL1820200000000000000000000000000000000000000000000000000000000000000000A8
< OK
> DL184020000000000000000000000000000000000000000000000000000000000000000088
< OK
> DL186020000000000000000000000000000000000000000000000000000000000000000068
< OK
> DL188020000000000000000000000000000000000000000000000000000000000000000048
< OK
> DL18A020000000000000000000000000000000000000000000000000000000000000000028
< OK
> DL18C020000000000000000000000000000000000000000000000000000000000000000008
< OK
> DL18E0200000000000000000000000000000000000000000000000000000000000000000E8
< OK
> DL1900200000000000000000000000000000000000000000000000000000000000000000C7
< OK
> DL1920200000000000000000000000000000000000000000000000000000000000000000A7
< OK
> DL194020000000000000000000000000000000000000000000000000000000000000000087
< OK
> DL196020000000000000000000000000000000000000000000000000000000000000000067
< OK
> DL198020000000000000000000000000000000000000000000000000000000000000000047
< OK
> DL19A020000000000000000000000000000000000000000000000000000000000000000027
< OK
> DL19C020000000000000000000000000000000000000000000000000000000000000000007
< OK
> DL19E0200000000000000000000000000000000000000000000000000000000000000000E7
< OK
> DL1A00200000000000000000000000000000000000000000000000000000000000000000C6
< OK
> DL1A20200000000000000000000000000000000000000000000000000000000000000000A6
> DL1A4020000000000000000000000000000000000000000000000000000000000000000086
> DL1A602000000102030400000000000000000000000000000000000000000000000000005C
> DL1A801C000000000000000000000000000000000000000000000000000000004A
< OK
< OK
< OK
< OK
> DL1AC4200004040404020000000007000000000000000000000000000000000000000000E9
< OK
> DL1AE41C00000000000000000000000000000000000000000000000000000000E6
< OK
> DL1B2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD
< OK
> DL1B4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D
< OK
> DL1B6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
< OK
> DL1B8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D
< OK
> DL1BA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D
< OK
> DL1BC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D
< OK
> DL1BE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD
< OK
> DL1C0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDC
< OK
> DL1C2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBC
< OK
> DL1C4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9C
< OK
> DL1C6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7C
< OK
> DL1C8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5C
< OK
> DL1CA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C
< OK
> DL1CC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1C
< OK
> DL1CE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC
< OK
> DL1D0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDB
< OK
> DL1D2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBB
< OK
> DL1D4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9B
< OK
> DL1D6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7B
< OK
> DL1D8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5B
< OK
> DL1DA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3B
< OK
> DL1DC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1B
< OK
> DL1DE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB
< OK
> DL1E0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDA
< OK
> DL1E2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA
< OK
> DL1E4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9A
< OK
> DL1E6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7A
< OK
> DL1E8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5A
< OK
> DL1EA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3A
< OK
> DL1EC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1A
< OK
> DL1EE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA
< OK
> DL1F0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9
< OK
> DL1F2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB9
< OK
> DL1F4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF99
< OK
> DL1F6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79
< OK
> DL1F8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59
< OK
> DL1FA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39
< OK
> DL1FC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19
< OK
> DL1FE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9
< OK
> DL200820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8
< OK
> DL202820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8
< OK
> DL204820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98
< OK
> DL206820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
< OK
> DL208820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF58
< OK
> DL20A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38
< OK
> DL20C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
< OK
> DL20E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8
< OK
> DL210820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD7
< OK
> DL212820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7
< OK
> DL214820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF97
< OK
> DL216820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF77
< OK
> DL218820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF57
< OK
> DL21A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF37
< OK
> DL21C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF17
< OK
> DL21E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7
< OK
> DL220820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD6
< OK
> DL222820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB6
< OK
> DL224820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF96
< OK
> DL226820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76
< OK
> DL228820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF56
< OK
> DL22A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF36
< OK
> DL22C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF16
< OK
> DL22E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6
< OK
> DL230820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD5
< OK
> DL232820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB5
< OK
> DL234820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95
< OK
> DL236820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF75
< OK
> DL238820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF55
< OK
> DL23A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF35
< OK
> DL23C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF15
< OK
> DL23E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5
< OK
> DL240820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD4
< OK
> DL242820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB4
< OK
> DL244820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF94
< OK
> DL246820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF74
< OK
> DL248820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF54
< OK
> DL24A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF34
< OK
> DL24C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF14
< OK
> DL24E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4
< OK
> DL250820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3
< OK
> DL252820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3
< OK
> DL254820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93
< OK
> DL256820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
< OK
> DL258820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53
< OK
> DL25A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF33
< OK
> DL25C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF13
< OK
> DL25E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3
< OK
> DL260820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
< OK
> DL262820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB2
< OK
> DL264820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF92
< OK
> DL266820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72
< OK
> DL268820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52
< OK
> DL26A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF32
< OK
> DL26C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12
< OK
> DL26E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2
< OK
> DL270820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1
< OK
> DL272820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1
< OK
> DL274820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
< OK
> DL276820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71
< OK
> DL278820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51
< OK
> DL27A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31
< OK
> DL27C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF11
< OK
> DL27E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1
< OK
> DL280820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0
< OK
> DL282820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0
< OK
> DL284820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90
< OK
> DL286820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70
< OK
> DL288820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
< OK
> DL28A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30
< OK
> DL28C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10
< OK
> DL28E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
< OK
> DL290820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
< OK
> DL292820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
< OK
> DL294820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F
< OK
> DL296820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F
< OK
> DL298820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F
< OK
> DL29A820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F
< OK
> DL29C820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F
< OK
> DL29E820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF
< OK
> DL2A0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE
< OK
> DL2A2820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE
< OK
> DL2A4820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E
< OK
> DL2A6820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
< OK
> DL2A8820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E
< OK
> DL2AA820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E
< OK
> DL2AC820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
< OK
> DL2AE820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE
< OK
> DL2B0820FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
< OK
> DL2B2820C16500000330306B0180670000FF21FF4B010768000000515149034E0800000093
< OK
> DL2B482006FF4B0487690000FF70704903806A0000FF32FF4A01876C0000FF0202490387D0
< OK
> DL2B68206D0000FF01014903C16B0000FF20FF4B010379000000FFFF4A01C1660000FF37DB
< OK
> DL2B8820374B01C2644A010310FF4B01CD710000FF51FF4B01C06E0000FC02FF4801C06F5F
< OK
> DL2BA82000000331FF4A0100C50000007070480500867A000001FF480480EE00000301FFE0
< OK
> DL2BC820480600BF00000001FF4804008300000006FF480406C6000000FFFF4A010BE500BB
< OK
> DL2BE82000007373490380F20000FF50FF480407F8000000505049030AD5000000FFFF487F
< OK
> DL2C0820060077000000FFFF480480EE0000FF01FF4806074700000352524903804A00001F
< OK
> DL2C2820FFFFFF4806000900000000004806807F00000313FF4904FFFFFFFFFFFFFFFFFF92
< OK
> DL2D5620800101FFFFFFFFFF800100FFFFFFFFFF800201FFFFFFFFFF800200FFFFFFFFFF69
< OK
> DL2D7620800301FFFFFFFFFF800300FFFFFFFFFF800401FFFFFFFFFF800400FFFFFFFFFF41
< OK
> DL2D9620800501FFFFFFFFFF800500FFFFFFFFFF800601FFFFFFFFFF800600FFFFFFFFFF19
< OK
> DL2DB620800701FFFFFFFFFF800700FFFFFFFFFF800801FFFFFFFFFF800800FFFFFFFFFFF1
< OK
> DL2DD620810101FFFFFFFFFF810201FFFFFFFFFF810302FFFFFFFFFF810402FFFFFFFFFFDD
< OK
> DL2DF620810503FFFFFFFFFF810603FFFFFFFFFF810704FFFFFFFFFF810804FFFFFFFFFFA5
< OK
> DL2E16208C2030C341010FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5
< OK
> DL2E3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49009202026400FFFFFFFFFFFFFFFFFF52
< OK
> DL2E5620C3410105FFFFFFFFC3410107FFFFFFFFC3410205FFFFFFFFC3410207FFFFFFFF3E
< OK
> DL2E7620C3410305FFFFFFFFC3410307FFFFFFFFC3410405FFFFFFFFC3410407FFFFFFFF16
< OK
> DL2E9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3C
< OK
> DL2EB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC34C0105FFFFFFFFC34C0107FFFFFFFFE8
< OK
> DL2ED620C20700053300FFFFFFFFFFFFFFFFFFFF4A42C20700053100FFFFFFFFFFFFFFFF62
< OK
> DL2EF620490092010304FFFF490092010204FFFF0AFFFFFFFFFFFFFF4900730949098E0251
< OK
> DL2F162002480271024800FFFFFFFFFFFFFFFFFF841002730101FFFF4900730949098E02ED
< OK
> DL2F36200248014800FFFFFFFFFFFFFFFFFFFFFF490092070249098E02034700FFFFFFFFE7
< OK
> DL2F5620C3410001FFFFFFFFC341000DFFFFFFFF090601400AFFFFFF4701FFFFFFFFFFFFB4
< OK
> DL2F7620490073024702FFFF490073024704FFFF490073024803FFFF490073024801FFFF23
< OK
> DL2F962049009102014802FFFFFFFFFFFFFFFFFF8410027302400FFFFFFFFFFFFFFFFFFFAC
< OK
> DL2FB620FFFFFFFFFFFFFFFF08C3410001FFFFFFFFFFFFFFFFFFFFFFC512000100FFFFFF2C
< OK
> DL2FD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF821405FFFFFFFFFF821406FFFFFFFFFFBE
< OK
> DL2FF620490092010205FFFF56087309C208001E000083070053078F04035508710115FFBB
< OK
> DL301620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBA
< OK
> DL303620490A720448004802FFFFFFFFFFFFFFFF87011EFFFFFFFFFFC3410003FFFFFFFF83
< OK
> DL305620841001FFFFFFFFFF841000FFFFFFFFFF08FFFFFFFFFFFFFF5B01FFFFFFFFFFFFE4
< OK
> DL30762063205B08FFFFFFFF63405B04FFFFFFFF63205B07FFFFFFFF5B1BFFFFFFFFFFFF09
< OK
> DL3096206320860600FFFFFF63805B0BFFFFFFFF5B18FFFFFFFFFFFF63805B0AFFFFFFFF18
< OK
> DL30B62063805B09FFFFFFFF5C01581EFFFFFFFF63805B24FFFFFFFF5E01FFFFFFFFFFFF31
< OK
> DL30D6205E02FFFFFFFFFFFF5B1CFFFFFFFFFFFF63805B11FFFFFFFF850801FFFFFFFFFF3B
< OK
> DL30F6204200FFFFFFFFFFFF4201C20800037500FFFFFFFFFFFFFFFF5D025B19FFFFFFFF32
< OK
> DL31162016FFFFFFFFFFFFFF5A00C20800147C00FFFFFFFFFFFFFFFF5A01FFFFFFFFFFFF89
< OK
> DL3136205812FFFFFFFFFFFF4F0E72084A2FC201012C3000FFFFFFFFFFFFFFFFFFFFFFFFB1
< OK
> DL315620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF79
< OK
> DL317620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF59
< OK
> DL319620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF39
< OK
> DL31B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF19
< OK
> DL31D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9
< OK
> DL31F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD9
< OK
> DL321620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB8
< OK
> DL323620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF98
< OK
> DL325620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF78
< OK
> DL327620FFFFFFFFFFFFFFFFC3420405FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
< OK
> DL329620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF38
< OK
> DL32B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF18
< OK
> DL32D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8
< OK
> DL32F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD8
< OK
> DL331620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB7
< OK
> DL333620FFFFFFFFFFFFFFFFC34E0001FFFFFFFF4A60FFFFFFFFFFFFFFFFFFFFFFFFFFFFD5
< OK
> DL3356204A42FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9
< OK
> DL337620FFFFFFFFFFFFFFFF6D04C3410109FFFFFFFFFFFFFFFFFFFF6D04C341010BFFFF4B
< OK
> DL339620FFFFFFFFFFFFFFFF6D04C3410209FFFFFFFFFFFFFFFFFFFF6D04C341020BFFFF29
< OK
> DL33B620FFFFFFFFFFFFFFFF6D04C3410309FFFFFFFFFFFFFFFFFFFF6D04C341030BFFFF07
< OK
> DL33D620FFFFFFFFFFFFFFFF6D04C3410409FFFFFFFFFFFFFFFFFFFF6D04C341040BFFFFE5
< OK
> DL33F620FFFFFFFFFFFFFFFFC3480105FFFFFFFFC3480107FFFFFFFFFFFFFFFFFFFFFFFFAB
< OK
> DL3416204F0973024E01FFFF4F0972024E01FFFF4F0A73024E02FFFF4F0A72024E02FFFF2C
< OK
> DL3436204F0B73024E03FFFF4F0B72024E03FFFF4F0C7300FFFFFFFF4F0C7200FFFFFFFFA8
< OK
> DL345620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF76
< OK
> DL3476204909730107FFFFFFFFFFFFFFFFFFFFFF49038E06138E03078D2E01FFFFFFFFFF32
< OK
> DL349620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49009102044AD6FF49098F0102C1490039
< OK
> DL34B620920A024003C207001EE50071024A49FF8D2E014908910302923604C20300B42C30
< OK
> DL34D62001C204012C3001C20A021C3101C20646503201C2071B4E3301C20300F02D01C2F9
< OK
> DL34F62004003C3001C20500C82F01C20A01723101910301925B03C20302712C01C2040164
< OK
> DL351620633001C20A02EE3101C20442683001C20600B03201C20A01773101C2060E102942
< OK
> DL35362001C20A0FA03001C20601183301C203015E2D01C20A00CC3101C205012C2F01492A
< OK
> DL35562004923A05C20303842C01C204012C30017102715EC20A02B43101C2060E103201D4
< OK
> DL357620C2044C2C3001C20601043301C20300962D01C20500502F01C20A00643101490842
< OK
> DL3596209221068D2C01C2060E103201C2071C202901C20340742D01C20600C83301C20429
< OK
> DL35B62000AF3101922B078D2C01C2060E1032017102711EC2071C202901C203300C330117
< OK
> DL35D620C20300B42D01C205012C2F01C20A00FA3101FFFFFFFFFFFF4F047203821401C7F2
< OK
> DL35F620FFFFFFFFFFFFFFFF4F027205C702BAD5FFFFFFFFFFFFFFFF491772024F047210FC
< OK
> DL361620C717BAD517BAD5820401C2400E101801FFFFFFFFFFFFFFFF49038E1B088D6B01D3
< OK
> DL363620C20200B42D014917720E560B720A4B02C20C070800004C02FFFFFFFFFFFFFFFFA1
< OK
> DL36562049038E13088D6A01C20100B42F0149177206C20B02580000FFFFFFFFFFFFFFFFC9
< OK
> DL36762049038E09088D2901C20200B4330149177208560B72044B074B06FFFFFFFFFFFF98
< OK
> DL369620C51200021EFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC51200030FFDFFFF4C
< OK
> DL36B620C512000300FFFFFFC51200050FFDFFFFC512000500FFFFFFC51200070FFDFFFF76
< OK
> DL36D620C512000700FFFFFFC51200020FFDFFFFC512000200FFFFFFC51200050FFD0FFE4B
< OK
> DL36F620C20503482C01C20604743001C20306363101C20421FC3201FFFFFFFFFFFFFFFFC3
< OK
> DL371620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB3
< OK
> DL373620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF93
< OK
> DL375620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF73
< OK
> DL377620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF53
< OK
> DL379620FFFFFFFFFFFFFFFFC51200070FFD0FFEC51200050FFD0FFEC51200030FFD0FFE3CLast edited on Sunday Nov 20th, 2011 01:42 am by
Posted: Saturday Nov 19th, 2011 09:46 am |
lwillerton
Posts: | 221 |
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
< OK
> DL37B620C51200020FFDFFFFC5120005320FFEC5120003320FFEC5120002320FFEC51200ED
< OK
> DL37D6200732FFFFFFFFFFFFC5120007000FFEC5120005000FFEC5120003000FFEC512000E
< OK
> DL37F6200200FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
< OK
> DL381620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5120002000FFEC20101682D01C202039B
< OK
> DL383620112D01C20303483001C20406182F01C20506403101FFFFFFFFFFFFFFFFFFFFFFAA
< OK
> DL385620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF72
< OK
> DL387620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF52
< OK
> DL389620FFFFFFFFFFFFFFFFC51200051EFFFFFFC51200031EFFFFFFFFFFFFFFFFFFFFFF36
< OK
> DL38B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF12
< OK
> DL38D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2
< OK
> DL38F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD2
< OK
> DL391620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB1
< OK
> DL393620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF91
< OK
> DL395620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF71
< OK
> DL397620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF51
< OK
> DL399620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF31
< OK
> DL39B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F0473058228017122
< OK
> DL39D62005C717BAD5FFFFFF4F0472058228017105C717BA46FFFFFF822802FFFFFFFFFFF5
< OK
> DL39F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD1
< OK
> DL3A1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0
< OK
> DL3A3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90
< OK
> DL3A5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70
< OK
> DL3A7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
< OK
> DL3A9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30
< OK
> DL3AB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10
< OK
> DL3AD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
< OK
> DL3AF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0
< OK
> DL3B1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
< OK
> DL3B3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F
< OK
> DL3B5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F
< OK
> DL3B7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F
< OK
> DL3B9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F
< OK
> DL3BB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F
< OK
> DL3BD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF
< OK
> DL3BF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
< OK
> DL3C1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE
< OK
> DL3C3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E
< OK
> DL3C5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
< OK
> DL3C7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E
< OK
> DL3C9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E
< OK
> DL3CB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
< OK
> DL3CD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE
< OK
> DL3CF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE
< OK
> DL3D1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD
< OK
> DL3D3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D
< OK
> DL3D5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D
< OK
> DL3D7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4D
< OK
> DL3D9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D
< OK
> DL3DB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D
< OK
> DL3DD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED
< OK
> DL3DF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
< OK
> DL3E1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAC
< OK
> DL3E3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8C
< OK
> DL3E5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6C
< OK
> DL3E7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4C
< OK
> DL3E9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2C
< OK
> DL3EB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0C
< OK
> DL3ED620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEC
< OK
> DL3EF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCC
< OK
> DL3F1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAB
< OK
> DL3F3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8B
< OK
> DL3F5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6B
< OK
> DL3F7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4B
< OK
> DL3F9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2B
< OK
> DL3FB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0B
< OK
> DL3FD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEB
< OK
> DL3FF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCB
< OK
> DL401620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAA
< OK
> DL403620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8A
< OK
> DL405620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6A
< OK
> DL407620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4A
< OK
> DL409620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2A
< OK
> DL40B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0A
< OK
> DL40D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEA
< OK
> DL40F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCA
< OK
> DL411620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA9
< OK
> DL413620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF89
< OK
> DL415620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF69
< OK
> DL417620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF49
< OK
> DL419620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF29
< OK
> DL41B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09
< OK
> DL41D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE9
< OK
> DL41F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC9
< OK
> DL421620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA8
< OK
> DL423620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF88
< OK
> DL425620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF68
< OK
> DL427620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF48
< OK
> DL429620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF28
< OK
> DL42B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF08
< OK
> DL42D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE8
< OK
> DL42F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC8
< OK
> DL431620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA7
< OK
> DL433620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF87
< OK
> DL435620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF67
< OK
> DL437620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF47
< OK
> DL439620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF27
< OK
> DL43B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF07
< OK
> DL43D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE7
< OK
> DL43F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC7
< OK
> DL441620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA6
< OK
> DL443620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF86
< OK
> DL445620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF66
< OK
> DL447620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46
< OK
> DL449620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF26
< OK
> DL44B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF06
< OK
> DL44D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE6
< OK
> DL44F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC6
< OK
> DL451620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA5
< OK
> DL453620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF85
< OK
> DL455620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF65
< OK
> DL457620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF45
< OK
> DL459620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF25
< OK
> DL45B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF05
< OK
> DL45D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5
< OK
> DL45F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC5
< OK
> DL461620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA4
< OK
> DL463620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF84
< OK
> DL465620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF64
< OK
> DL467620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44
< OK
> DL469620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF24
< OK
> DL46B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF04
< OK
> DL46D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE4
< OK
> DL46F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC4
< OK
> DL471620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA3
< OK
> DL473620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF83
< OK
> DL475620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF63
< OK
> DL477620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF43
< OK
> DL479620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23
< OK
> DL47B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03
< OK
> DL47D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3
< OK
> DL47F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
< OK
> DL481620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2
< OK
> DL483620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
< OK
> DL485620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF62
< OK
> DL487620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF42
< OK
> DL489620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF22
< OK
> DL48B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF02
< OK
> DL48D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE2
< OK
> DL48F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC2
< OK
> DL491620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA1
< OK
> DL493620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF81
< OK
> DL495620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF61
< OK
> DL497620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF41
< OK
> DL499620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF21
< OK
> DL49B620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF01
< OK
> DL49D620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE1
< OK
> DL49F620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC1
< OK
> DL4A1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
< OK
> DL4A3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80
< OK
> DL4A5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60
< OK
> DL4A7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40
< OK
> DL4A9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF20
< OK
> DL4AB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00
< OK
> DL4AD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0
< OK
> DL4AF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
< OK
> DL4B1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F
< OK
> DL4B3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F
< OK
> DL4B5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
< OK
> DL4B7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F
< OK
> DL4B9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F
< OK
> DL4BB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
< OK
> DL4BD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF
< OK
> DL4BF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF
< OK
> DL4C1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E
< OK
> DL4C3620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E
< OK
> DL4C5620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E
< OK
> DL4C7620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E
< OK
> DL4C9620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E
< OK
> DL4CB620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE
< OK
> DL4CD620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE
< OK
> DL4CF620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
< OK
> DL4D1620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D
< OK
> DL4D3618FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
< OK
> DL4D5620496E747275646572FFFFFFFFFFFFFFFF447572657373FFFFFFFFFFFFFFFFFFFF8C
< OK
> DL4D76204C696E65437574FFFFFFFFFFFFFFFFFF41726D4661696CFFFFFFFFFFFFFFFFFFDF
< OK
> DL4D96205A6F6E6554726F75626C65FFFFFFFFFF5A6F6E65416C657274FFFFFFFFFFFFFFFC
< OK
> DL4DB6204C6F7742617474657279FFFFFFFFFFFF506F7765724661696CFFFFFFFFFFFFFF54
< OK
> DL4DD62050616E6963FFFFFFFFFFFFFFFFFFFFFF456E747279416C657274FFFFFFFFFFFFD9
< OK
> DL4DF62054616D706572FFFFFFFFFFFFFFFFFFFF46697265FFFFFFFFFFFFFFFFFFFFFFFFC4
< OK
> DL4E1620476173FFFFFFFFFFFFFFFFFFFFFFFFFF46616D696C7943617265FFFFFFFFFFFF97
< OK
> DL4E3620506572696D65746572FFFFFFFFFFFFFF4279706173735A6F6E65FFFFFFFFFFFFAE
< OK
> DL4E562044697361726DFFFFFFFFFFFFFFFFFFFF434D5354657374FFFFFFFFFFFFFFFFFF6C
< OK
> DL4E762053797374656D41726D6564FFFFFFFFFF416C61726D41626F7274FFFFFFFFFFFFD4
< OK
> DL4E9620456E7472795761726E696E67FFFFFFFF536972656E54726F75626C65FFFFFFFF3E
< OK
> DL4EB620466F72636541726DFFFFFFFFFFFFFFFF5253343835436F6D6D73FFFFFFFFFFFF96
< OK
> DL4ED620446F6F7262656C6CFFFFFFFFFFFFFFFF486F6D6553616665FFFFFFFFFFFFFFFF91
< OK
> DL4EF6204469616C54657374FFFFFFFFFFFFFFFF534D5354726F75626C65FFFFFFFFFFFFC0
< OK
> DL4F16204E65774D657373616765FFFFFFFFFFFF456E67696E6565724469616CFFFFFFFFEF
< OK
> DL4F36205369676E696E54616D706572FFFFFFFF46726F6E74446F6F72FFFFFFFFFFFFFFF8
< OK
> DL4F56204261636B446F6F72FFFFFFFFFFFFFFFF4261636B476172616765446F6F72FFFFF4
< OK
> DL4F7620476172616765446F6F72FFFFFFFFFFFF476172616765504952FFFFFFFFFFFFFF1B
< OK
> DL4F9620436F6E7365727661746F7279446F6F72436F6E7365727661746F7279504952FF5F
< OK
> DL4FB6204C6F756E6765526F6F6D504952FFFFFF4B69746368656E504952FFFFFFFFFFFF41
< OK
> DL4FD620446F776E537461697248616C6C504952557073746169727348616C6C504952FFEE
< OK
> DL4FF6204D6173746572426564526F6F6D5049524D617374657242656450616E6963FFFF3C
< OK
> DL5016204775657374426564526F6F6DFFFFFFFF46726F6E74426564526F6F6DFFFFFFFF21
< OK
> DL5036204261636B426564526F6F6DFFFFFFFFFF5A6F6E653137FFFFFFFFFFFFFFFFFFFF4C
< OK
> DL5056205A6F6E653138FFFFFFFFFFFFFFFFFFFF5A6F6E65313930FFFFFFFFFFFFFFFFFF12
< OK
> DL5076205A6F6E653139FFFFFFFFFFFFFFFFFFFF447269766577617947617465FFFFFFFF56
< OK
> DL50962042726F6B656EFFFFFFFFFFFFFFFFFFFF466972655570737461697273FFFFFFFFC6
< OK
> DL50B62046697265476172616765FFFFFFFFFFFF5A6F6E653235FFFFFFFFFFFFFFFFFFFF1A
< OK
> DL50D6205A6F6E653236FFFFFFFFFFFFFFFFFFFF5A6F6E653237FFFFFFFFFFFFFFFFFFFFC5
< OK
> DL50F6205A6F6E653238FFFFFFFFFFFFFFFFFFFF5A6F6E653239FFFFFFFFFFFFFFFFFFFFA1
< OK
> DL5116205A6F6E653330FFFFFFFFFFFFFFFFFFFF5A6F6E653331FFFFFFFFFFFFFFFFFFFF8E
< OK
> DL5136205A6F6E653332FFFFFFFFFFFFFFFFFFFF5A6F6E653333FFFFFFFFFFFFFFFFFFFF6A
< OK
> DL5156205A6F6E653334FFFFFFFFFFFFFFFFFFFF5A6F6E653335FFFFFFFFFFFFFFFFFFFF46
< OK
> DL5176205A6F6E653336FFFFFFFFFFFFFFFFFFFF5A6F6E653337FFFFFFFFFFFFFFFFFFFF22
< OK
> DL5196205A6F6E653338FFFFFFFFFFFFFFFFFFFF5A6F6E653339FFFFFFFFFFFFFFFFFFFFFE
< OK
> DL51B6205A6F6E653430FFFFFFFFFFFFFFFFFFFF5A6F6E653431FFFFFFFFFFFFFFFFFFFFEC
< OK
> DL51D6205A6F6E65343230FFFFFFFFFFFFFFFFFF5A6F6E653433FFFFFFFFFFFFFFFFFFFF97
< OK
> DL51F6205A6F6E653434FFFFFFFFFFFFFFFFFFFF5A6F6E653435FFFFFFFFFFFFFFFFFFFFA4
< OK
> DL5216205A6F6E653436FFFFFFFFFFFFFFFFFFFF5A6F6E653437FFFFFFFFFFFFFFFFFFFF7F
< OK
> DL5236205A6F6E653438FFFFFFFFFFFFFFFFFFFF5A6F6E653439FFFFFFFFFFFFFFFFFFFF5B
< OK
> DL5256205A6F6E653530FFFFFFFFFFFFFFFFFFFF5A6F6E653531FFFFFFFFFFFFFFFFFFFF49
< OK
> DL5276205A6F6E653532FFFFFFFFFFFFFFFFFFFF5A6F6E653533FFFFFFFFFFFFFFFFFFFF25
< OK
> DL5296205A6F6E653534FFFFFFFFFFFFFFFFFFFF5A6F6E653535FFFFFFFFFFFFFFFFFFFF01
< OK
> DL52B6205A6F6E653536FFFFFFFFFFFFFFFFFFFF5A6F6E653537FFFFFFFFFFFFFFFFFFFFDD
< OK
> DL52D6205A6F6E653538FFFFFFFFFFFFFFFFFFFF5A6F6E653539FFFFFFFFFFFFFFFFFFFFB9
< OK
> DL52F6205A6F6E653630FFFFFFFFFFFFFFFFFFFF5A6F6E653631FFFFFFFFFFFFFFFFFFFFA7
< OK
> DL5316205A6F6E653632FFFFFFFFFFFFFFFFFFFF5A6F6E653633FFFFFFFFFFFFFFFFFFFF82
< OK
> DL5336105A6F6E653634FFFFFFFFFFFFFFFFFFFF6B
< OK
> DL5746205521FFFF45FFFFFF20FFFFFF1BFFFFFF2506FFFF17BAFFFFFFFFFFFFFFFFFFFF68
< OK
> DL576620FFFFFFFFFFFFFFFF17BAFFFF12C7FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF95
< OK
> DL578620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF23
< OK
> DL57A620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF03
< OK
> DL57C620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE3
< OK
> DL57E620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC3
< OK
> DL580620FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA2
< OK
> DL582610FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF82
< OK
> DL588620D4FFFF4A01D3FFFF520153FFFF4E01FFFFFF0000FFFFFF0000FFFFFF0000FFFF2C
< OK
> DL58A620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000051D4FF320151D3FF3342
< OK
> DL58C620015153A52901FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF5E
< OK
> DL58E620FFFF0000FFFFFF0000FFFFFF000051D4FF2D0151D3FF2C015153A56B01FFFFFF56
< OK
> DL5906200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000093
< OK
> DL592620FFFFFF00003951D42E013951D32F015153A56A01FFFFFF0000FFFFFF0000FFFF9E
< OK
> DL594620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000051D4FF30FD
< OK
> DL5966200151D3FF31015153A50000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF8F
< OK
> DL598620FFFF0000FFFFFF0000FFFFFF0000FFFFFF000017BAFF900112C7FF9201FFFFFF43
< OK
> DL59A6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000F3
< OK
> DL59C620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFD5
> DL59E620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00B4
< OK
< OK
> DL5A062000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF93
< OK
> DL5A2620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF74
< OK
> DL5A46200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000052
< OK
> DL5A6620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF34
< OK
> DL5A8620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0013
< OK
> DL5AA62000FFFFFF0000D5FFFF900146FFFF9201FFFFFF0000FFFFFF0000FFFFFF0000FFB2
< OK
> DL5AC620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000D5AF4607
< OK
> DL5AE6209401FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00001D
< OK
> DL5B0620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF93
< OK
> DL5B2620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0072
< OK
> DL5B462000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF52
< OK
> DL5B6620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF33
< OK
> DL5B86200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000011
< OK
> DL5BA620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFF3
< OK
> DL5BC620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00D2
< OK
> DL5BE62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFB2
< OK
> DL5C0620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF92
< OK
> DL5C26200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000070
< OK
> DL5C4620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF52
< OK
> DL5C6620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0031
< OK
> DL5C862000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF11
< OK
> DL5CA620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFF2
< OK
> DL5CC6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000D0
< OK
> DL5CE620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFB2
< OK
> DL5D0620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0090
< OK
> DL5D262000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF70
< OK
> DL5D4620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF51
< OK
> DL5D66200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00002F
< OK
> DL5D8620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF11
< OK
> DL5DA620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00F0
< OK
> DL5DC62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFD0
< OK
> DL5DE620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFB1
< OK
> DL5E06200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00008E
< OK
> DL5E2620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF70
< OK
> DL5E4620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF004F
< OK
> DL5E662000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF2F
< OK
> DL5E8620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF10
< OK
> DL5EA6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000EE
< OK
> DL5EC620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFD0
< OK
> DL5EE620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00AF
< OK
> DL5F062000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF8E
< OK
> DL5F2620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF6F
< OK
> DL5F46200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00004D
< OK
> DL5F6620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF2F
< OK
> DL5F8620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000E
< OK
> DL5FA62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFEE
< OK
> DL5FC620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFCF
< OK
> DL5FE6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000AD
< OK
> DL600620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF8E
< OK
> DL602620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF006D
< OK
> DL60462000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF4D
< OK
> DL606620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF2E
< OK
> DL6086200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00000C
< OK
> DL60A620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFEE
< OK
> DL60C620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00CD
< OK
> DL60E62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFAD
< OK
> DL610620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF8D
< OK
> DL6126200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00006B
< OK
> DL614620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF4D
< OK
> DL616620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF002C
< OK
> DL61862000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF0C
< OK
> DL61A620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFED
< OK
> DL61C6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000CB
< OK
> DL61E620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFAD
< OK
> DL620620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF008B
< OK
> DL62262000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF6B
< OK
> DL624620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF4C
< OK
> DL6266200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00002A
< OK
> DL628620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF0C
< OK
> DL62A620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00EB
< OK
> DL62C62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFCB
< OK
> DL62E620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFAC
< OK
> DL6306200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000089
< OK
> DL632620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF6B
< OK
> DL634620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF004A
< OK
> DL63662000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF2A
< OK
> DL638620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0B
< OK
> DL63A6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000E9
< OK
> DL63C620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFCB
< OK
> DL63E620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF00AA
< OK
> DL64062000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF89
< OK
> DL642620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF6A
< OK
> DL6446200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF000048
< OK
> DL646620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF2A
< OK
> DL648620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0009
< OK
> DL64A62000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFE9
< OK
> DL64C620FFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFFCA
< OK
> DL64E6200000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000A8
< OK
> DL650620FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFF89
< OK
> DL652620FF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0068
< OK
> DL65462000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FFFFFF0000FF48
< OK
> DL656604FFFF000033
< OK
> DL69B61821FFFFFFBAAFC7B8FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3
< OK
> DL69D620180803161608111611082216040833165507461643075916310712171707251751
< OK
> DL69F6200207391746065117300604181406161857052918410541182505531809050519DD
< OK
> DL6A1620540417193904291926044119140453190404032056031320500321204603272076
< OK
> DL6A362045033120470333205103322057032820050421201504132025040220360450193E
< OK
> DL6A5620480437195904221911050719220551183405351846051818570501180906451745
< OK
> DL6A762021062917330613174606581658064316110730162407191636070916480701164B
< OK
> DL6A96205807551507085315130853151708561560032531071025310732FFFFFFFFFFFF3A
< OK
> DL6AB601FFE0
< OK
> RS
> LI
< OK
< LU00
> LI****
> UL000003
> V?
> v?
> U?
> LI
< LU02
< DL00000305FF22D7
< V?FE060522200100
< U?0A060211
< LU00
> UB01010A
> UB01010A
> UB01010A
< V?FE060522200100
< Z?00010000
< M?0002
< a?000000000000000000
< V?FE060522200100
< Z?00000000
< M?0002
< V?FE060522200100
< Z?00000000
< M?0002
> LI****
> UL000003
> V?
> v?
> U?
> SR01
> DT20111119094854
> DT20111119094854
> DT20111119094854
> LI
< LU02
< DL00000305FF22D7
< V?FE060522200100
< U?0A060211
< OK
< LU00
> LI****
> UL000003
> UL000003
> UL000003
> LI
< LU02
< LU00
> LI****
> LI****
> LI****
> LI****
> LI****
> LI****
Posted: Sunday Nov 20th, 2011 01:40 am |
The last log seems to indicate that the write operation was completed and Comfigurator reset the system
< OK
> DL6AB601FFE0
< OK
> RS
> LI
< OK
< LU00
What was the problem
What are you trying to do below?
UB01010A is upgrading UCM Firmware using the programming cable. Why are you attempting to do this?
> LI****
> UL000003
> V?
> v?
> U?
> LI
< LU02
< DL00000305FF22D7
< V?FE060522200100
< U?0A060211
< LU00
> UB01010A
> UB01010A
> UB01010A
< V?FE060522200100
< Z?00010000
Posted: Sunday Nov 20th, 2011 12:21 pm |
lwillerton
Posts: | 221 |
Hi Ident
I was just trying to do actions to talk to the system to see if it failed to communicate. I did a lot of system info requests as well and uploaded a config change.
I have alway intended upgrading the ETH UCM to 6008 from 6002 to see if this makes the ETH comms more stable and though I could do this by selecting upgrade firmware. When I tried it says update failed with errors.
I might be over complicating this, but the basics are either using a xover cable or on my network I seem to loose comms which requires a reset on the ETH UCM board.
When I was in the US the iPhone app worked great for a couple of weeks, but then lost comms altogether ETH reset sorted. If I use comfigurator I seem to loose comms a lot sooner guaranteed within 24hrs. This is when I am making config changes as I learn more about the programming.
I really appreciate your help.
Lee
Posted: Monday Nov 21st, 2011 12:32 am |
Can you give me the serial number on the UCM and the ETH module. It sshould be P or C followed by numbers on a sticker with bar codes
Posted: Monday Nov 21st, 2011 05:51 am |
lwillerton wrote: Hi Ident
You tried to upgrade UCM6.002 to 6.008
This is good but it looks like you selected the option Upgrade by Programming Cable
This is for upgrading another module with the UCM. It cannot be used for upgrading the same UCM. To upgrade a UCM using this method you need to use another UCM
If you want to upgrade the UCM itself then you must use the method Upgrade by Direct connection to PC
This is why you had the error
The upgradiing procedure is fully described in the UCM Manual from http://www.cytech.biz/ucm_manual.html
Do read the chapter on firmware upgrading before you attempt it otherwise you may end up corripting the firmware
