Playing Memos in responses on Comfort 1
 Posted: Monday Sep 8th, 2008 10:28 am
ghylwood
Is there a rule I am missing when memos are played in a response on Comfort 1? Sometimes they play fine then I made a minor adjustment to an unrelated response and it stopped the memo playing; all other actions in same response work fine. I have even tried putting the memo in its own response and then ‘Do X response’ next. The X response will work but it still misses playing the Memo.
ALSO, What I was originally trying to do just will not work at all; I wanted to play a response and then follow it by ‘Say Time’ Is there some rule which says you have to wait until the first response has played before you can start another Memo?
 Posted: Monday Sep 8th, 2008 12:58 pm
The rule is that only one message can be played at any time. The messages do not queue up. The latest message will override another message which has not been played.
You can use timer delays to stagger the messages if you have more than 1
 Posted: Monday Sep 8th, 2008 07:19 pm
ghylwood
Could this be the reason that sometimes no message at all is played, because I have sent 2 comands for memo and  then 'Say Time' one after the other and confused it?
 Posted: Tuesday Sep 9th, 2008 02:11 am
Possible. Try the delay and you should hear both messages
 Current time is 07:31 am
