| Posted: Sunday Aug 2nd, 2009 07:15 pm |
hunters
| Posts: | 2 |
| Status: |
can somebody help on providing the reponse code for the following
Announce Zone + Switch output 1 (the output is from from the slave expansion panel(REM) 01 this is the one which is currently set to zone numbers 17-24) for 5 minutes latched on
the above will be attached to an on reponse to an external GJD detector which will only activate in the noght during its own internal light sensor
thanks
raj
| Posted: Monday Aug 3rd, 2009 07:39 am |
TheMax74
| Posts: | 170 |
| Status: |
If you write this response using response wizard, below the response wizard window you will find the response code, i think. You can write down the code and use it.
| Posted: Monday Aug 3rd, 2009 07:40 am |
hunters
| Posts: | 2 |
| Status: |
brilliant i will try
thanks
