Response on PIR ON not working as desired
 Posted: Thursday Nov 27th, 2014 02:15 pm
nbexiga
HI
I want to know why this piece of code that i added in the response does not work. what can be fixed. The objective it when the PIR Sensor is set to ON and the SecurityMode=SecurityOff but only from 19h00 to 07h (7pm to 7am) (this code is in the ON Response) , it do the response IL_HALL_ON
But only the part that is working is the ony below , i want that part to work but i want that the other part work too.
Do C_Hall_60If SecurityMode = AwayMode Or SecurityMode = NightMode Then    Do IL_Hall_On
Please see atached the piece of code that is in the response that i need to put working.
Can anybody help me?Thanks
Attachment: FredDomotica.txt (Downloaded 5 times)
 Posted: Thursday Nov 27th, 2014 05:52 pm
The problem is in the line
    If SecurityMode = SecurityOff And Hours > 19 And Hours < 7 Then
Think of the Hours as a number between 0 to 23
It is logically impossible to have Hours > 19 AND Hours < 7 at the same time
The correct form of the condition should be
    If SecurityMode = SecurityOff And Hours > 19 OR Hours < 7 Then
     That means Hours 19 to 23 OR 0 to 7 will meet the condition
 Posted: Thursday Nov 27th, 2014 06:33 pm
nbexiga
Hi slychiu
yes it makes sense that logically of the hours, i tried to change to the corrected form that you input but when i hit apply it appear the message in the atached file... :(Thanks
Attachment: Error.JPG (Downloaded 47 times)
 Posted: Thursday Nov 27th, 2014 07:35 pm
nbexiga
HI
it's already working ;) thanks for your help.
i changed to the code that is on the file
 Posted: Friday Nov 28th, 2014 05:21 am
You can shorten the Response like this
    Do IL_Hall_On
Else
    If SecurityMode = SecurityOff Then
        If Hours >= 18 Or Hours < 7 Then
            Do IL_Hall_On
        End If
    End If
End If
 Posted: Saturday Nov 29th, 2014 03:40 pm
nbexiga
many thanks ;) working! ;)
 Current time is 02:44 am
