| Posted: Wednesday Mar 19th, 2008 01:40 pm |
Warby
| Posts: | 101 |
| Status: |
I am trying to test the following response and every time it does both actions. Immersion off is Outputs 1 and 2 Off. In the moniter window it turns them both on then both off straight away. I am setting/Clearing the flag using a response. i also tried using to IF statements one for flag on the other for flag off with the same result. Am i missing sometrhing simple?
If Flag Immersion <> 0 Then
Output ImmersionOn-Off1 On
Output ImmersionBoost On
Else
Do ImmersionOff [Immersion Off]
End If
| Posted: Wednesday Mar 19th, 2008 08:11 pm |
| Posts: | 1032 |
| Status: |
I cannoty see anything wrong with the response, but can you send the ccl file to support@cytech.biz ? There may be something else which is switching off yje outputs
| Posted: Monday Mar 24th, 2008 05:07 am |
hendy
| Posts: | 155 |
| Status: |
In Configuration > Modules and Settings, tick "Use Branch Actions". This determines whether branch actions will be used to implement If/Then/Else statements. By default this has been ticked to enable the feature but somehow in your ccl file it is unticked.
| Posted: Monday Mar 24th, 2008 06:26 am |
hendy
| Posts: | 155 |
| Status: |
Your immersion response is working under normal condition i.e. will still be triggerred by time programs but for some reasons if you didn't tick the "Use Branch Actions" and execute the response directly from comfigurator, it seems to ignore If/Else statements and execute outputs on and off consecutively.
| Posted: Tuesday Mar 25th, 2008 11:26 am |
Warby
| Posts: | 101 |
| Status: |
Thanks that is now working fine, New it would be something simple!!
| Posted: Tuesday Mar 25th, 2008 11:55 am |
| Posts: | 1032 |
| Status: |
More info on this issue;
The SKIP action does not work in the DA command. Skip actions were the old way of skipping past a group of actions until a Marker action. These were replaced by Branch Actions. Branch actions are used omly when the box "Use Branch Actions" is checked. For old Comfort firmware, ie Comfort I, branch actions are noto implemented so the box should be unchecked. Comfoort II systems should leave the box checked
