Door Contacts in Series EOL
 Posted: Thursday Sep 18th, 2014 06:07 am
carrington
I have three door contacts in my property wired in series connected back to a single "door/window" zone. The door contacts were previously wired back to a Gardtec alarm panel that I have replaced with a Comfort II. As the gardtec panel used higher resistor values i have replaced the resistors with the equivalent Comfort resistor. Unfortunately i am now in a situation where the panel detects "trouble" whenever a contact is open. I assume i have a resistor in the wrong location? But don''t know for sure.
I have looked through the installation manual for a diagram covering how the contacts should be wired and where the resistors should be placed but could not see anythihg. I have ended up in a bit of muddle and wonder if anyone is able to point me in the direction of an idiots guide?
Thanks,
David
 Posted: Thursday Sep 18th, 2014 06:09 am
The figure in the Installation manual shows how to connect the EOL resistors, as shown below
Disregard the Tamper if the contact does not have a tamper terminal
The "Alarm" in the figure is the contact, but in your case it is 3 contacts in series.
The 4K7 resistor should be in parallel to all the 3 contacts. This may be a bit difficult depending on your wiring. You  cannot connect the resistor in parallel to each contact
The 2K7 (actually changed to 2K2) resistor should be in series with the zone
The zone shunt should be inserted away from the terminal block
alternatively, use the NO EOL setting which does not require any EOL resistors and move the shunt to the position closer to the terminal block
Attachment: eol.jpg (Downloaded 26 times)
 Posted: Thursday Sep 18th, 2014 05:14 pm
wiredhome
Here's a diagram of how to wire them up on the comfort
Attachment: DUAL END OF LINE Model (1).pdf (Downloaded 6 times)
 Posted: Thursday Sep 18th, 2014 05:42 pm
Here is a jpg of the IDAS diagram, thanks to wiredhome
Attachment: DualEndOfLine-Idas.jpg (Downloaded 21 times)
 Posted: Saturday Sep 20th, 2014 08:05 pm
carrington
Thank you both for the reply. In the cold light of day this is much simpler than I had thought!
Everything is now working correctly.
Thanks again!
 Current time is 08:53 am
