Posted: Sunday Jul 28th, 2019 07:49 am |
Posts: | 5499 |
Comfort Firmware 7.160
Known Bugs
- Force arm on partition using # key does not work always send to partition 0
- Partitions do not work well with UCM log in with ETH03
- CT counter report – if counter response changes another counter value, the counter report for the changed counter has the same conter id as the original. So if KNX sends a counter update, counter response change another counter and the counter is reported to knx, the counter id remains as KNX ucm id so the KNX ignores the new counter report.
- Upgrade CM9001 by ETH03 plug in. If reset occurs while upgrade, set baud rate for eth03 is not done.
- query_serialno bug in self id – sent serial no of Rs485 wrong. Broadcast serial no at reset instead of send serial no queries to id
- Doorphone action 9 partition 1 spkr/mic are turned on for doorphone intercom instead of doorphone ID
- From 7.159 increment counter, decrement counter actions did not return counter value as last action value so If action which follows uses the wrong value
Bugs Fixed- Fixed BUG For Partition Systems trouble alarms are registered into random partition and Restore may be registered to different partition so cannot acknowledge
Actions (Comfigurator 3.12.13)- Action 160 - switch S12V off time if time = 0, dont start timer for on time
- Action 159, 0, 3 Convert 256 to 100 use fractional value and round off
- Actions subtract parameters for Action 149, 3 (immediate), 149, 4 (counter), 149, 5 (sensor)
Event Log- Eventlog - command E?FF last event Fixed BUG did not work
- For EMS sensor event log, if module which reported sensor has Communications Failure, set sensor value to 255 so KP04A display does not remain unchannged as last value reported, and causes alarm
Partitions- If there is no partition 0, trouble alarms report in lowest partition
- For partition system turn off all keypad speakers first so only partition keypad can hear siren sound and announcement
Keypad- KP06A Keypad volume has max 100. KP06A volume is actually divided by 2
GSM- If an SMS dialout fails, immediately go to the next dial without time out delay
Counters- The Counter Response is also activated when Comfort changes a Counter value. Eg by Responses/ Action codes or Control menu. Previously, Counter Response is avtivated only when the counter us changed by a UCM
CM9001-EMS Environmental Monitoring System- Support Fractional Values for KP04A display
- Implemented Sensor calibration with Fractional value 1/16 for EMS
- Sensors adjustment for scale fix bug for division
- For EMS sensor event log, fixed BUG that sensors 9 onwards are not recorded correctly. Changed so that any sensor with counter assigned is recorded in event log every hour
- Sensor Register calibration in eepron is 1/16 units to use calibration value with 1/16 unit calibration value from eeprom
Comfort Protocol - ETH03 plug in support UN command
- s? s! Comands retiurn 3rd byte
- For plug in eth03 for LGX, UCM/LOG, CM9001, Sensor, Counter, Flag command will echo state eg C! Will report CT
UCM/Logic, KNX/Logic - No of Responses number from 1024 to 512 affect ucm/log, knx/logic
- Removed x10 responses not used affect knx/logic and ucm/logic
- KNX/Logic saved nonvolatile counters increased from 8 to 32
Posted: Friday Dec 11th, 2020 02:48 am |
Posts: | 5499 |
Comfort Firmware 7.164 (10 Sept 2019)
- Fixed bug from 5/11/18 sent serial no broadcast to RS485 at reset instead of query, causes delay at reset before start
- Controller does not query serial no at reset, Only query serial no when UCM ID info is received reply is received,
- Changes for test mode only
- Save counters and Flags in EEPROM implemented for EMS. Counters and flags are not cleared by Soft Reset (ie pressing the reset button or RS command) reset , they are cleared only when power off. EMS use counters and flags for temperature and setpoints.
