Posted: Sunday Apr 19th, 2020 06:37 am |
Posts: | 5493 |
Firmware 7.175
Known Issues- Partition keypad Security Check function (F,3,2) caused Zones for the wrong partition to be announced. Zone Detection for all partitions is t is OK. From 7.163
- From 7.159 increment counter, decrement counter actions did not return counter value as last action value so If action which follows uses the wrong value
- For Partitioned systme, when user logs in for partition >0, every minute the partition may be changed to to 0 so the user may arm or disarm to partition 0
- For wifi01 plugin if ucm does not log out, idle timer from EEPROM expires does not reset Wifi module. so if wifi lost connection, the module is not reset
- Old bug - if there is zone trouble in a partitioned system at reset, the partition keypad will show "Communications Failure" without ID (instead of zone trouble)- This is removed after sign in on keypad. When the user signs in on the Keypad, it shows "Zone 1 Trouble" instead of the correct zone number.
- Old Bug - if zone trouble is force armed when armed, after disarmed, the zone trouble is not shown until armed again or security check
- when sign in when zone trouble announce zone and user name was wrong
Bugs Fixed- Fixed bug - Protocol Input OFF message IPnn did not report after unbypass and zone closed
- Fixed bug from 5/11/18 sent serial no broadcast to RS485 at reset instead of query, causes delay at reset before start Dont query serial no at reset, Only query serial no when id info reply is received, so UCM can get it
- Doorbell action set ID=31H doostation ID1 instead of 241 which is F1 partition 1 Fixed Bug DA09 did not turn on Doorbell mic and speaker
- Fixed bug sometimes virtual input is missed. Multiple zones trigger during sensitivity timer was missed
- Fixed old BUG record greeting message press # will return to program menu. Voice menu not corect
- Fixed BUG upgrade CM9001 by bus sometimes fails at UB02 but firmware was not erased
- Fixed Bug Counter report CT – if counter reponse changes anothr counter, the counter report for the changed counter has the same conterid as the original. So if KNX send counter, counter response change another counter and the counter iss reported to knx, the counterid remaiins as KNX ucm id so the KNX ignores the new counter report
- Fixed Bug Doorbell Response creating endless loop
- Fix Bug Counter report – if counter reponse changes another counter, the counter report for the changed counter has the same conterid as the original. So if KNX send counter, counter response change another counter and the counter iss reported to knx, the counter id remaiins as KNX ucm id so the KNX ignores the new counter report
- CM9001-EMS fix bug from EMS 7.159 – if counter setpoint is out of limits, setpoint is changed to within limit but the counter value is not updated correctly and causes endless loop
Action Codes- Action 161 Change Login Partition,. If User is enabled for several parttions, user is logged into the lowest partition. Change Log in Partition changes the partition to another enabled partition. Cytech app will process different partitions correctly for alarm states and commands and arming and disarming for plug in ETH03 and UCM 7.124
- Action 9 Doorbell in test mode dont send DB31
- Action 27 motion detector zone response for hotel monitoring for ULT and OPT
- Action 65 add add parameter 2 for check status Bell
- Action 73 add parameter 32 occupancy
Occupancy Detection
Supports Occupancy Detection in Comfigurator see http://www.comfortforums.com/forum20/5158.html - Motion for Occupancy sensor enable for OPT, ULT LGX
- Implement dR and d? For occupancy detection
BS8243- For BS8243, if the zone is the same as (unconfirmzone) then it is not confirmed alarm
- For BS8243, fire alarm will not set notification fixed from 10/11/19 which did not work
Wifi- Support wifi01 submodule on CM9001
- If wifi01 detected leave baudrate at 38400, and leave parity as none
- FS34 FS31.FS36. FS37 FS39 add eeprom location 255 idle time out in minutes for wifi (default 5 minutes)
- Add rs485 message 0b2h for wifi timeout value reply to ucm query
- Every hour for wifi do auto update time from NTP for wifi submodule
- If wifi eeprom time out in location 0x00ff= 255, dont start_wifitimeout. Only 0 did not start timer before
- For wifi run timer to reset wifi based on location 255 in minutes (default 5 minutes) when receiving is idle, or when log in and log out, and continue to run the timer after that so wifi is reset at regular intervaes when not logged in
Timers- Implement Timer value message Trttvv sent to the UCM which logged in only, instead of broadcast to prevent too much delays, Timer value will update every second to the UCM logged in, but when the UCM logs out, The timer RS485 message will not be sent to the UCM. Supports Timer Status in Register Monitor see http://www.comfortforums.com/forum20/5149.html
- No of Timers change from 16 to 32 for LGX01 and ucm/logic , also 32 for ems
Keypad User Responses- Misc Events >User Responses is enabled for sign-in on keypad. Previously this was for fingerprint reader, now obsolete. Skip announce action 23 in the keypad User response will exit and not go into the keypad menu . If skip announce action 23 is not in the user response, sign in will go to the user menu as normal. if keypad user response is not zero, the keypad sign in is recorded in the event log
- see http://www.comfortforums.com/view_topic.php?id=5162&forum_id=126 for example
Counters/Flags- Save 32 counters in eeprom and 256 Flags enabled for ucm/log, lgx01,knx/log, EMS not for OPT and ULT
- KNX/Logic implement nonvolatile 32 counters
KP06A Volume- KP06A Keypad volume is increased for the same setting (75% instead of 50%)
GSM- Supports DTMF key detected by GSM module not depending on DSP for GSM4 (3G) and LTE.
Misc- RS485 Receive time out adjusted to increase time out
- For test mode, only allow 1 UCM and 1 KP ID. Production test problem when cm9001 detects no of keypads and ucms >1 get comms fail.
- Test mode Flag warm start will not clear test mode, so that test mode does not scan IDs modules again
Posted: Sunday Apr 19th, 2020 09:49 am |
Chiu, where can we get this software as it isn't advertised in Comfigurator yet.
Posted: Sunday Apr 19th, 2020 10:12 am |
Posted: Tuesday May 26th, 2020 10:44 am |
Posts: | 5493 |
Please tTake note of a bug found in ULT 7175 Beta- Partition keypad Security Check function (F,3,2) caused Zones for the wrong partition to be announced. Zone Detection for all partitions is t is OK. From 7.163
This does not affect the actual detection of zones in any partition
