Comfort Home Automation/ Security System Forums > Support > Tips, Tricks and Tutorials > Play Message on the Door Station when the doorbell is pressed
 Posted: Monday Nov 23rd, 2009 02:07 pm
When a visitor presses the doorbell, you can greet him by playing a recorded message.
This is done by recording a reminder message and using the Doorbell Response to Play Reminder message on the Door Station
The Response
Reminder 1 On Keypad 49
means Play Reminder Message 1 on Door station 1
You can select all Keypads and Door stations, any keypad, any Door station or all keypads, or all door stations on which to play the reminder message
You need to record the reminder message for this to work
You can also add other actions eg to turn on the porch lights to the same Response
The screenshot below shows how the Response is created
Attachment: PlayRemonDoorbell.jpg (Downloaded 74 times)
 Posted: Monday Nov 23rd, 2009 02:17 pm
The example Response is attached in zip form for those who are new to this and which to try it out
Look at Events > Misc Events > Doorbell Response to see the Response which plays the record reminder Message
You will need to record a reminder message on Reminder 1 in this example
Steps;
  1. enter the user menu by signing in on the keypad
  2. Press 2 for Messages,
  3. Press 5 for Reminder Messages
  4. Keypad says "Enter Reminder message and # key" Enter 1# for reminder 1,
  5. Press 4 for messages and 1 to record message.
  6. Record your message and press any key to end
  7. Press 2 to hear your message and 1 to record over again if necessary
Attachment: PlayMessageDoorStation.zip (Downloaded 21 times)
 Current time is 06:07 am
