Search
Search:
go
Search by username
Menu
Members
Calendar
Help
Not logged in -
Login
Register
Support
Questions on Programming Comfort
> Eng Test Mode
Eng Test Mode
Moderated by:
New Topic
Reply
Printer Friendly
Rate This Topic
Excellent
Good
Fair
Poor
Horrible
Author
Post
Posted: Saturday Nov 12th, 2011 09:33 pm
PM
Quote
Reply
1
st
Post
lwillerton
Sunday Oct 2nd, 2011
221
Hi All,
How do I turn a comfort Ultra II in to a mode where it is safe to remove the main system case without setting off the tamper alarm?
Cheers
Lee
Posted: Saturday Nov 12th, 2011 11:11 pm
PM
Quote
Reply
2
nd
Post
schford
Wednesday Feb 25th, 2009
248
Hope this helps...Cut from a post in which I asked same question!
http://www.comfortforums.com/forum1/2505.html
Press F0 then engineer code and # key
Press 8,6,1
This will allow you to open the box without alarm
However you must remember to disable it by engineer Menu 8,6,0 after you finish
schford
Posted: Sunday Nov 13th, 2011 12:43 am
PM
Quote
Reply
3
rd
Post
lwillerton
221
Cheers.... will try that in the morning.... next door will cause me harm if I wake them up playing about now :-)
Thank for the quick response.
Current time is 01:29 pm
Support
> Eng Test Mode
Forum Jump -->
These Forums
....Forum/Website
....NEWS & Announcements
Support
....How to Use Comfigurator
....Automation Programming
....Responses and Actions
....Wishlist
....Wordlist
....Training
....FAQs - Technical
....FAQs - Users
....Troubles
....Vocabulary Issues
....Arming and Disarming
....Outputs
....Keypad
....Comfort I Issues
....Door Stations
....Comfort as Fire Alarm
....Firmware History
....Comfort Firmware
....Keypad Firmware
....Slave Firmware
....Technical Material
Products
....CM9001
....Logic Controllers
....KP06/KP06A/KP04A Keypads
....KP06A/KP04A Firmware
....Temperature Sensor
....UCM
....UCM/USB
....Ethernet UCM/ETH03
....UCM/Wifi
....UCM Firmware
....UCM Problems
....UCM/Pi
....UCM/ETH01 & UCM/ETH02
....GSM Module
....UCM/GSM Firmware
....IRIO
....Expansion Modules
....Relay/Automation Modules
....Door Stations
....Door Station Problems
....KT03 Firmware History
....SCS Firmware History
....RIO Firmware
Software Applications
....iOS Apps
....Comfigurator
....Comfigurator 2.X
....Comfort Android App
....ComfortClient
....Plug-in Development
....ComfortClient Plug-ins
....WizComfort
....Misc Software Interfaces
....KNX (EIB)
....KNX Support
....UCM/KNX Firmware
....CBus
....UCM/CBUS Problems
....UCM/CBUS Firmware
....Universal UCM
....UCM/Modbus
....Zwave
....UCM/Zwave Firmware
....Smart-House/Dupline
....C-Bus to KNX Translator
....Velbus
....UCM/Velbus Firmware
....Heatmiser
....ULTI
....Wireless Security
....Remote Controls
....Lighting Interfaces
....Access Control
....Miscellaneous Interfaces
....Companion
....X10
Comfort Around The World
....Cytech Media Coverage
....Assistive Living
....Events / Diary
....Miscellaneous UK Issues
....Comfort Installers Forum
....Security and Monitoring
General HA Information
....Miscellaneous
....HA in the News
Restricted
....Special Problems
UltraBB 1.172
