Comfort Automation/ Security System Forums > Products > RIO (OBSOLETE - Replaced by IRIO) > Same IR code on different receivers; different responses possibility?
 Posted: Tuesday Feb 1st, 2011 09:13 am
siamak
I know it may seem useless but, assume two receivers  connected to two separate RIO inputs, can we assign different responses for the same IR code depending on which IR receiver has received the code? say same key on RC01.
I'm looking for a way to do this: in a building with many doors,  each door can be opened only if the person is in front of it pressing a key on RC. and from there none of the other doors could be opened.
 Posted: Wednesday Feb 2nd, 2011 12:52 am
You cannot assign different responses for the same IR code
Perhaps you can get the person to press a button on the door and send the IR code. Then the Response can test for the button being pressed and release that door
 Posted: Friday Feb 4th, 2011 11:44 am
siamak
Thank you
 Current time is 01:40 pm
