Open gate with DMO2
 Posted: Wednesday Apr 29th, 2020 01:33 pm
theshepherdmatt
Hi guys,
I have recently purchased a farfisa PL11P bundle with a DM02, I have successfully installed the door station and DM02 and all is well.
Phase-2
Now I need Comfort to open my gates via the keypad and this is where my knowledge and programing of comfort is limited.
Any help will be much appreciated
Many thanks
Matt
 Posted: Thursday Apr 30th, 2020 01:29 am
Here are the instructions to open door/gate using DM02
Programming the Door/Gate Relays
A door strike or automatic gate can be opened from the Door Station menu. The two menu commands;
“4 to Open Gate, 7 to Open Door”
can be programmed to open a gate or a door using a relay connected to any Comfort output or the relays K1 (Gate) and K2 (Door) on the DM02.
  • Go to Comfigurator > Events > Miscellaneous  Events and look for the events Open Door Response and Open Gate Response in the list.
  • Select or create a Response to be assigned to Open Door Response and Open Gate Response as required. If no Response is selected, the corresponding menu to Open Gate and/or Open Door will not be announced. Once a nonzero Response is selected, the corresponding menu item will be announced.
  • To control the relays K1 and K2 on a DM02, use Action 200 (Open Door). In Response Wizard select Output > Open Door, then select the Door Station ID, the Door number 1 for K1 (Gate) and 2 for K2 (Door), and the duration in 100 ms units.
  • If there is more than 1 Door Station, use the IF Door Station ID action to program the outputs according to the ID of the door station eg
If  DoorStationId = 49 Then
    Pulse Output01 For 20
Endif
If  DoorStationId = 50 Then
        Pulse Output02 For 20
Endif
If  DoorStationId = 51 Then
        Pulse Output03 For 20
End If
The above Response for Open Gate or Open Door Response will pulse Output 1 for DP ID 1, output 2 for DP ID2 and Output 3 for DP ID 3.
Note that the relays are rated at 30VDC 3 A
 Current time is 09:59 am
