UCM/KNX2 firmware 7.122 to 7.131
 Posted: Sunday Jul 21st, 2019 04:34 am
  • KNX Monitor mode includes Send to KNX
  • UCM/KNX2 alarms and Inputs to KNX work with Partitioned alarm system. Older Firmware does not support partitions
 Posted: Wednesday Aug 14th, 2019 05:56 pm
I have an issue on site today
Just upgraded an early C2 5.xxx to latest 7.xxx
System had been working OK for 10 years - as soon as I loaded the new firmware onto the KNX UCM 7.079 I get a fire alarm triggered from UCM02 (18) clear this and a few minutes later same thing - then a panic alert from the UCM........
Looking at the UCM it reads OK from the EPROM BUT when I download to EPROM it DOES NOT WORK the screen flashes but actually nothing happens same with reset. This is confirmed by the fact that the read still contains data even after a reset !
CAN YOU PLEASE TEST THIS OUT AS IM ON SITE AGAIN TOMMOROW and need to get it fixed.
 Posted: Thursday Aug 15th, 2019 02:49 am
When you Reset to Default in UCM/KNX2, it clears the KNX screen and properties to default, but it does not write to EEPROM. You have to do Write to KNX after a reset to default in order to write to KNX
 Posted: Thursday Aug 15th, 2019 04:59 am
Tested with Comfigurator 3.12.15. Write to KNX and read from KNX worlksCan youdo a write and copy the Monitor IO
 Posted: Friday Aug 16th, 2019 02:27 pm
OK
I have remote connection .....How do I know if the UCMKNX is 1 or 2 ?
 Posted: Friday Aug 16th, 2019 02:32 pm
Scan for modules  The module type will be seen
 Posted: Friday Aug 16th, 2019 02:35 pm
OK that was a stupid question ........ its a 1 as it does not say knx2 and only has limited no of tabs
 Posted: Saturday Aug 17th, 2019 02:07 am
Its easy to change the KNX module to a  KNX2
 Posted: Wednesday Jul 1st, 2020 02:23 am
UCM/KNX 7.131
  •  Fixed BUG during Read from KNX which may cause UCM/KNX to stop working
  •  Fixed BUG sensor to KNX did not work report
 Posted: Wednesday Jul 1st, 2020 02:29 pm
TheMax74
Hi Chiu,
sorry for importunating you.
Does the UCM/KNX2 respond to READ requests coming from KNX BUS?
For example, if i map a Group Address to a Zone input and send a READ telegram to this Group Address, does the UCM/KNX2 respond with the current zone status?
 Posted: Thursday Jul 2nd, 2020 01:36 am
Yes the UCM/KNX2 does respond to a Read request.
 Current time is 06:48 pm
