Posted: Monday Sep 13th, 2021 07:23 am |
Ian
Posts: | 249 |
I would like to set the time of comfort to be the same as my LAN. I know there is the opportunity when transferring to Comfort, but can I do it from a response?
Posted: Monday Sep 13th, 2021 08:41 am |
You can synchronise the comfort time with Internet time if you have a UCM/ETH03 or ETH03 plugin (for CM9001). If you do not have it, It cannot be done with a Response because the response will not know what is the trime as the PC is not always connected
Posted: Monday Sep 13th, 2021 08:42 am |
Posted: Monday Sep 13th, 2021 08:51 am |
Posted: Monday Sep 13th, 2021 10:21 am |
Ian
Posts: | 249 |
Thank you for responding. I am aware that I can synchronise manually. I was hoping to automate the process, hence my request if it could be done via a response that I could activate at intervals via MQTT-python.
Posted: Monday Sep 13th, 2021 11:02 am |
ETH03 sync with NTP Internet time is automatic, not manual, you set the interval eg 1 hour.
Posted: Monday Sep 13th, 2021 11:41 am |
