UCM/Zwave Firmware 7.010 (Beta)
 Posted: Friday Feb 1st, 2013 08:20 am
UCM/Zwave Beta Firmware 7.010 can be downloaded from http://www.cytech.biz/product_details.php?item_id=288 for testing purposes
This firmware has new features which requires Comfigurator 3.6.4 or above which is described in http://www.comfortforums.com/view_topic.php?id=3261&forum_id=20
The new UCM/Zwave Manual version 3 can be downloaded from http://www.cytech.biz/product_details.php?item_id=230
New Features
  1. UCM/Zwave will update status bar on Comfigurator Zwave screen .
  2. After Virtual Node operations UCM/Zwave  will automaticallly read EEPROM when required and send to Comfigurator without having to Learn the network again from the primary controller
  3. Zwave Action has a new Multilevel Dimming function
  4. UCM/Zwave will update Comfort counters and sensors from Zwave commands even when the counter value has not changed. This allows status of Zwave devices controlled by Comfort and other Zwave nodes to be synchronised
The status messages show the status of the UCMs which were formerly available only by seeing the state of the LEds BUSY1, BUSY2, ERROR eg for Zwave
  • Normal/No error
  • EEPROM missing/faulty
  • EEPROM insufficent capacity
  • EEPROM data invalid
  • Communication error between UCM baseboard and Z-wave sub-module
  • UCM/Z-Wave not in any network
  • Waiting to receive network data. (Learn process)
  • Receiving network data. (Learn process)
  • Writing EEPROM. (Learn process)
  • Learn process success
  • Learn process completed with errors
  • Command transmitted.  Waiting for ACK
  • Z-Wave network busy/jammed (RF transmit error)
  • Unknown transmit error
 Posted: Sunday May 12th, 2013 05:56 pm
gaynorc
I see on the downloads area a version 7.014 which is not indicated to be a Beta version. However I cannot find an entry in the forum for this 7.014 as the latest firmware, nor a description of its effects. Can you point me to the page please?
 Posted: Monday May 13th, 2013 08:38 am
Zwave 7.014 is the latest beta firmware which you can download from http://www.cytech.biz/product_details.php?item_id=288
Please note that if you downloaded Zwave 7.014 from the server before today, it was the wrong version uploaded by mstake
Please use the Zwave 7.014 with todays date
This is still in beta
 Current time is 08:02 pm
