- Pgordon - 01-26-2017 Hmm... hold fire on that one...after going to the app on the phone, then coming back to the IDE, it seems I had been logged out (inactivity timer?) - so I logged back in to my ST account, and went back to the My SmartApps, and My Device Handlers sections... There\'s nothing there!!! I *absolutely definitely* saw each and every one of them put up the green banner saying \"published successfully\" after every single one of the 11 items... ***k knows where they\'ve gone then... Right... I\'ll repeat myself and go through all of them again... Will let you know the outcome Cheers. Paul G. - DavidJ - 01-26-2017 Go to Automation - Third from bottom - Then Smartapps alongside Routine in second bar down from top. - DavidJ - 01-26-2017 [user=139]Pgordon[/user] wrote: Quote:Hmm... hold fire on that one...after going to the app on the phone, then coming back to the IDE, it seems I had been logged out (inactivity timer?) - so I logged back in to my ST account, and went back to the My SmartApps, and My Device Handlers sections... Dont repeat logout and login again. It sometimes gets confused. Or try a different browser. I\'m sure it will be there. - mattbrain - 01-26-2017 Hi Paul Just looking through the telemetry and your Pi isn\'t able to connect to the alarm. Can you please check the configuration of the alarm, specifically the IP address and port number as set up in your UCM/Eth. Also, can you re-attempt registration please? Finally, can you click on the send button under logs - that will help me see if there is anything else going on. Thanks, Matt - mattbrain - 01-26-2017 [user=1738]DavidJ[/user] wrote: Quote:https://graph.api.smartthings.com/Hi David, Paul (Many thanks to David for stepping in and providing guidance - that\'s a huge help). SmartThings can be a little \'picky\', if you have a UK SmartThings hub, it is likely registered to the UK portal (https://graph-eu01-euwest1.api.smartthings.com) - the generic North American one should redirect, but I would suggest logging into the UK one if your device is from the UK just to be sure your settings are to be applied correctly to your hub. Thanks, Matt - Pgordon - 01-26-2017 mattbrain wrote: Quote:Also, can you re-attempt registration please?Logs sent... Got a clue for the registration... if the \"Send Continuous Usage Data\" checkbox is ticked, hitting the Register button does nothing... as soon as I cleared that, hit send, the dialog box closes, and I presume it has sent... Cheers. Paul G. - Pgordon - 01-26-2017 DavidJ wrote: Quote:Oops. sorry. too slow... I already did it...Quote:Dont repeat logout and login again. It sometimes gets confused. Or try a different browser. I\'m sure it will be there. it worked the 2nd time.... phone app found the My Apps section, and showed the Comfort device... I\'ve added it & it is running discovery... it has discovered 35 devices, and seems to have stopped at that point.. - it\'s been running some 15 mins or so now, and has not increased, so I presume that\'s all there is to find.. - it\'s not obvious here when it has \"finished\" - no window pops up to say so...Cheers Paul G. - DavidJ - 01-26-2017 [user=139]Pgordon[/user] wrote Quote: Oops. sorry. too slow... I already did it... Yep it normally takes 5 mins or so you can always go back.Click on the list of the discovered devices and select (via checkbox) the ones you want displayed in the smartthings \"things\" area.You do need to get your head around smartthings though which is by trial and error. THe community site is relatively helpful. - mattbrain - 01-26-2017 [user=139]Pgordon[/user] wrote: Quote:DavidJ wrote:Quote:Oops. sorry. too slow... I already did it...Quote:Dont repeat logout and login again. It sometimes gets confused. Or try a different browser. I\'m sure it will be there. Ah, thats the nature of pure UPNP discovery - you never actually know when it is complete (as new stuff may pop on and off the network at any time). I\'m thinking of revising this process so UPNP is used to initiate the process, but a master device then reports on all it\'s children which don\'t use UPNP in the same way. I\'m going o give this some thought as it will mean changing pretty much all the code and i\'m not sure the immediate benefit is worth the effort when i want to work on some other stuff. Thanks, Matt - DavidJ - 01-26-2017 For What its worth. I don\'t think its a biggee, not a real major issue at all. Maybe we could start some sub-forums that Chiu set up. Also this forum is now getting a bit overpowering for a newbie to follow, perhaps split off, to setup/new feature requests/Smartthings/Etc. |
