- mattbrain - 01-26-2017 [user=1738]DavidJ[/user] wrote: Quote:For What its worth. I don\'t think its a biggee, not a real major issue at all. Maybe we could start some sub-forums that Chiu set up. Also this forum is now getting a bit overpowering for a newbie to follow, perhaps split off, to setup/new feature requests/Smartthings/Etc.You read my mind - I\'m going to take some time after I get the update to fix your door station issue out to add some topics. I am thinking of: Latest Release Link and Notes FAQ Device Wish List Roadmap Anything else you would like to see? - DavidJ - 01-26-2017 No rush on door station. The integration now with Core, via the ability of it knowing set/unset is awesome has opened up so many opportunities. With regard to forum its useful to read through a full thread to understand the likely hurdles and how to overcome. This thread has now become a bit cumbersome to follow. Otherwise I think you\'ve covered all relevant elements for now. - Guest - 01-26-2017 Matt, just setting up Raspberry, smartthings all seem work as expected, add device also succesfull.... Marvelous work .. trying to turn on off one device from smartthings app , not working... I think only need to learn more about this ...maybe because still very new for me My system has 96 output installed, with zwave ucm, GSM4, 3 IRIO ( with sub modules ). - mattbrain - 01-26-2017 [user=5404]bagushandhoko[/user] wrote: Quote:Matt,Fantastic - glad you have got it working. Would you mind sharing your serial number with me and I can take a look in the telemetry to see if it is talking to your comfort panel ok? Thanks, Matt - Guest - 01-26-2017 [user=912]mattbrain[/user] wrote: Quote:[user=5404]bagushandhoko[/user] wrote:just registered.... by the way, what do you think better for your system , amazon echo or google home ?Quote:Matt,Fantastic - glad you have got it working. Would you mind sharing your serial number with me and I can take a look in the telemetry to see if it is talking to your comfort panel ok? - Guest - 01-26-2017 [user=139]Pgordon[/user] wrote: Quote:Hmm... hold fire on that one...after going to the app on the phone, then coming back to the IDE, it seems I had been logged out (inactivity timer?) - so I logged back in to my ST account, and went back to the My SmartApps, and My Device Handlers sections...Happen to me too, at first uploading... after back from work, open the smartthings web,, nothing there, create again ... and ... working - mattbrain - 01-26-2017 [user=5404]bagushandhoko[/user] wrote: Quote:[user=912]mattbrain[/user] wrote:Quote:[user=5404]bagushandhoko[/user] wrote:just registered.... by the way, what do you think better for your system , amazon echo or google home ?Quote:Matt,Fantastic - glad you have got it working. Would you mind sharing your serial number with me and I can take a look in the telemetry to see if it is talking to your comfort panel ok? I haven\'t tested with Google Home - so Echo is highly recommended. Integration is currently via SmartThings but am planning on direct integration to drive adoption. Thanks, Matt - Guest - 01-27-2017 anyone has experience like this ? Hi Matt, this is the answer from smartthings support : Tony (SmartThings) Jan 26, 6:58 PM MST Hi there, Thanks for reaching out to SmartThings Support! Taking a look, it appears that this issue is associated with a Custom SmartApp, which is something that we won\'t have much insight to since we had no part in developing it. What I would suggest is going to our Community to see if the creator of the app can lend a hand with this issue or if anyone else has some insight, as the users there will have more experience with Custom SmartApps and the like. Apologies that I don\'t have more here, but if there was anything more I can help with feel free to let me know! Warm regards, Tony SmartThings Support - DavidJ - 01-27-2017 Smartthings support are useless. First port of call is always community. THats a weird error you have and one I have not seen. - mattbrain - 01-27-2017 Hi Bagushandhoko I suspect the UPNP discovery on SmartThings has got into a mess - when you redid discovery, did you do it via the existing App instance or create a new one - it\'s quite confusing as once you run it for the first time, it creates a copy of the App in a new location. I need to provide more detailed instructions to do manage all this, and I\'ll try to do it today. My recommendation, from the web gui, delete all the devices in the My Devices tab, remove the SmartApp and re-add and publish it and start again. Let me know how you get on. Thanks, Matt |
