Word lists - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 2.X (https://www.comfortforums.com/forum-67.html) +---- Thread: Word lists (/thread-1132.html) |
- Vicente - 08-04-2008 I select the template Comfort Pro (There is no option for Comfort I Pro) Then the option that I can see are: - Standard residential - Chinese residential - UK residential - Pagewatch - Australian residential - slychiu - 08-04-2008 Can you open vocust.cfg in the Comfigurator folder and check that the contents are >Custom WordList 00=Promenade,promnfor.cfg,sentence.cfg 01=Spanish Comfort I,cs-wl-sp.cfg,sentence_spa.cfg 02=Portuguese_v7,cs-wl-pt_v7.cfg,sentence-pt_v7.cfg Check that the files cs-wl-sp.cfg and sentence_spa.cfg are found in the same folder Also copy the vocab.cfg file to the same folder in case it was corrupted - Vicente - 08-04-2008 vocust.cfg is exactly as you wrote: >Custom WordList 00=Promenade,promnfor.cfg,sentence.cfg 01=Spanish Comfort I,cs-wl-sp.cfg,sentence_spa.cfg 02=Portuguese_v7,cs-wl-pt_v7.cfg,sentence-pt_v7.cfg I unzip the vocab.cfg and rewrite in the comfigurator folder. and still it doesn\'t work. - Vicente - 08-04-2008 I\'m sorry to disturb you so many times, I really don\'t undertand what happen with the files. - slychiu - 08-05-2008 I suspect that Comfigurator is using a different folder than what you used to save the files Copy this default.cfg into the same folder, then ipen a new fiile and see if you can see Comfort I Ultra and Comfort I PRO in the list. If not then the folder is not the same - Vicente - 08-05-2008 I did and I can see COMFORT I PRO , and COMFORT I ULTRA, COMFORT I ENTRY, so the folder is the same. Where I live we say: I don\'t believe in Witches, but they exists...... Could you send a copy of you configurator file in which you made the changes and it works? Regards Vicente - slychiu - 08-05-2008 Curiouser and curiouser! Check the attached file. I have zone 1 programmed with some spanish words and the wordlist is Spanish Comfort I I wonder if the problem could be due to your Spanish windows language - Vicente - 08-05-2008 Yes, I see zone 1 with spanish words. You are right. - Vicente - 08-05-2008 What do you mean with: \"I wonder if the problem could be due to your Spanish windows language\" Can I change something in windows Spanish language? Thank for your help. - slychiu - 08-06-2008 If you can see the Spanish words now, then there should be no problem Are you able to create a new file and select Spanish? |
