Comfort and Homeeasy - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Miscellaneous Interfaces (https://www.comfortforums.com/forum-47.html) +--- Thread: Comfort and Homeeasy (/thread-1765.html) |
- ident - 01-29-2011 Where is the information of RFXCOM Rs232 interface and the protocol? - CYMD - 01-29-2011 when talking about RS232 stop bit, sometimes we can see 1,1.5,2 stop bits, that means the level of stop bit maintain timing is 1, 1.5 and 2 tims , actually all RS232 stop bit is 1 - palmlodge - 01-29-2011 http://www.rfxcom.com/index.htm - ident - 01-29-2011 There does not seem to be aby info on Rs232 interfaces or stop bits on that link - bs85 - 01-29-2011 All technical info has been removed from the RFXCOM site. - ident - 01-29-2011 [user=3791]CYMD[/user] wrote: Quote:when talking about RS232 stop bit, sometimes we can see 1,1.5,2 stop bits, that means the level of stop bit maintain timing is 1, 1.5 and 2 tims , actually all RS232 stop bit is 1The problem is that these devices may expect 1.5 or 2 stop bits from the transmitting device but if the transitter is only capable of sending 1 stop bit before the next character, then it may not be received correctly and cause a frame error If the receiver expects 1 stop bit then 1.5 or 2 stop bits is OK. - palmlodge - 01-31-2011 I believe RFXCOM are now in discussion with Cytech. IMHO, this \"reverse\" X10 RF protocol is one of the best - and my whole house is CBUS. - slychiu - 01-31-2011 Yes we are talking with RFXCom directly now - palmlodge - 03-03-2011 Hi As you have the RFXCOM interface now, have you had any success in purely sending the commands from the UCM to the HomeEasy devices ? Thanks - slychiu - 03-04-2011 We can send the commands to RFXcom and receive the commands, but still studying how the interface should be handled |
