Comfort Firmware 5.195 to 5.199 - Printable Version
+--- Forum: Firmware History (https://www.comfortforums.com/forum-60.html)
+---- Forum: Comfort Firmware (https://www.comfortforums.com/forum-79.html)
+---- Thread: Comfort Firmware 5.195 to 5.199 (/thread-1873.html)
Pages: 1 2
- slychiu - 06-12-2010
Does the scan consistently fail to see the UCM/Zwave? What version is the UCM/Zwave?
- juwi_uk - 06-12-2010
Yep it consistently fails. Appears that u?12 and u?13 are not responding which are my Zwave and Smartfit UCM\'s respectively.  The zwave UCM is flashed to the current (latest) firmware.
> LI****
> UL000003
> V?
> v?
> U?
> u?11
> u?12
> u?13
> u?14
> u?15
> u?16
> u?17
> u?18
> LI
< LU01
< LR0111
< DL00000305FF22D7
< V?FE05C322200100
< v?05FF1E010103FFFF
< U?0A05D411
< u?110A05D4
< u?14FFFFFF
< u?15FFFFFF
< u?16FFFFFF
< u?17FFFFFF
< u?18FFFFFF
< LU00
Chiu,
It didnt find the new GSM/UCM I\'ve just purchased either.  Surely that should have the latest firmware and be found.  Says 5.163 on the flash chip.
Sorry, my mistake it did find the UCM/GSM it just didnt set the version.
- slychiu - 06-13-2010
The UCM firmware required to report the firmware version is 5.168, so as your UCM/GSM is 5.163 it will report 0000
We shall shortly be releasing updated firmware to all ucm types which will be abble to report the firmware version
- slychiu - 07-06-2010
ULT 5.199 fixes the bugs found in the beta version 5.195 in this thread
[size=\"3\"]Changes
[/size]
  1. Allow delay of 300 ms after any reset command on Rs485 bus to allow modules to be reset and wake up.
  2. Fixed Portugal Answering number of rings problem after 5.173 caused problem
  3. Fixed BUG  for invalid login accepted by RS485 in 5.186 (Firmware Not Released)
  4. Fix bug where u? query id whose firmware does not support this query.  CM does not reply to UCM. when null reply received , reply to querying id 0000 if id exists Tested on old KP and DP which dont support 7DH command. They do NOT reply at all to 7DH or to any commands they dont recognise instead of replying with NULL message.
  5. Fixed Bug from 5.195 UCM Keypad  eg Wizcomfort wrong code or Duress code entered, it logged out UCM
  6. Fixed Bug from 5.195 when KP comes on line when there is trouble , LCD is blank until trouble condition changes
  7. Implement received unknown command reply for for module ids which do not recognise command, to handle new commands which are not suported bny modules with older firmware
Known Issues
  1. If a trouble condition  occurs followed by 2nd trouble condition, then the 2nd trouble is cleared, when sign in the 2nd trouble condition is still announced until both troubles are cleared. From 5.188
  2. SCS 9 to 15 temperature could not be reported (old problem)
- juwi_uk - 07-25-2010
I\'ve noticed that point 2. in the New Features section of the fix list at the start of this thread just says \"improvements\";  in what though? Smile
- slychiu - 07-25-2010
Not sure, cant have been importantSmile
I think these have been described in later 5.199
