Comfigurator 3.2.8 Feedback/Questions - Printable Version
+---- Thread: Comfigurator 3.2.8 Feedback/Questions (/thread-2231.html)
Pages: 1 2
- bs85 - 04-16-2011
Also got this error when clicking on the Modules and Settings in comfigurator.
Upgraded from 3.2.7 to 3.2.8
Code:
Exception while reading vocab.cfg:
System.Exception: Error reading C:\\Program Files\\Cytech\\Comfigurator 3\\Config\\vocab.cfg: Could not find file \'C:\\Program Files\\Cytech\\Comfigurator 3\\Config\\cs-wl-th.cfg\'.
   at Comfort.Vocab.AddWordLists(Configuration configuration, String filename, List`1 wordlists)
   at Comfort.Vocab.GetWordLists(Configuration configuration)
- ident - 04-16-2011
This problem was reported by gaynorc in a previous post in this topic. There is a  missing file which was attached
[user=3375]bs85[/user] wrote:
Quote:Also got this error when clicking on the Modules and Settings in comfigurator.
Code:
System.Exception: Error reading C:Program FilesCytechComfigurator 3Configvocab.cfg: Could not find file \'C:Program FilesCytechComfigurator 3Configcs-wl-th.cfg\'.
- siamak - 04-17-2011
Thanks for the new version.
With \"Extend range of valid characters in Names of Zone, Alarms etc\", now it\'s possible to make Comfort control other Comfort panels in case needed. Like this.
- ident - 04-17-2011
I didnt even think of that possibility (sending SMS to another Comfort to control it). Nice!
- ident - 04-18-2011
Quote:When doing a learn request i see activity on the velbus network after about 30 seconds a message \"No responce to Velbus Learn Request\" pops up.
After clicking ok it continues to reed the UCM/Velbus EEPROM when finished any new module or address change shows correctly in the Velbus to Comfort window.
Comfigurator 3.2.8
Comfort 5.211
UCM/Velbus 5.228
Does this happen every time you learn/scan the Velbus network or only occasionally?
There is a new version Velbus 5.229 in the Velbus forum which fixes this occasional error message, see http://www.comfortforums.com/view_topic.php?id=2151&forum_id=88
Please post all  messages about Velbus on that UCM/Velbus forum
This topic has too many threads already and will be closed
Please post a new topic for other issues regarding the new Comfigurator
