KP06 Keypad - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: KP06/KP06A/KP04A Keypads (https://www.comfortforums.com/forum-105.html) +--- Thread: KP06 Keypad (/thread-2523.html) |
- ident - 10-28-2011 There is an Esprit White Glass Frame which would probably be a better match. Be warned that these Glass Frames are pretty expensive - schford - 10-28-2011 I like the standard Cream White Glossy I am going to change my order :-) - Ingo - 10-28-2011 I see the sample photo\'s show a 12H clock. Is there an option to change to 24H? Ingo - ident - 10-29-2011 There are many options in the LCD menu which can be changed on the keypad but not 24 hours. The Time only shows 12 hours format - ident - 10-29-2011 The Cytech Website has been updated to show the range of KP06 Keypads with frames, https://www.cytech.biz/keypads.html The KP06 manualcan be downloaded from https://www.cytech.biz/kp06_manual.html - Home - 10-29-2011 Excellent news I think that more needs to be made of the different frame surrounds available. Palmlodge was asking abut CBUS - if you are putting CBUS next to the keypad then you will notice a difference in size colour and texture - if they are some distance apart then you may get away with it. The european frame sizes are rather confusing and i need to get a better understanding before i relay more info - however companies such as Jung Gira Merten (owned by schneider) Siemens ABB etc (basically any of the KNX manufacturers) all offer a large selection of surrounds. Many offer the european fitments to cover all UK outlets such as power sockets and fuse spurs. This in effect menas that ALL of your wall funniture - lighting, thermostats, alarm, multi-room audio can all be fitted with the same surround plates. Perhaps cytech could place a few more offerings may be a basic white and SS and aluminium and a brass..... A - Home - 10-29-2011 Do cytech plan to mould a WHITE insert as well as the black? A AdminYes! see http://www.comfortforums.com/forum105/3727.html - ident - 10-30-2011 The Gira Standard 55 Pure white and cream are available in Gloss and Matt finishes. These are good choices for the KP06 (I personally like the glossy versions), and are quite reasonlbly priced. The E2 series is alaos available in white although more costly. I believe other KNX manufacturers may have similar Hence there is no need for Cytech to produce another white coloured frame. One of the reasons that we designed the product this was was to allow customers to have a very wide choice of frames beyond what we can supply ourselves - Home - 10-31-2011 INSERT - are there plans for Cytech to have a batch of WHITE INSERTS to go with white frames.. Black inserts with white frames will not work aesthetically. Surely next time your moulder does a run you can take a batch of white instead of black? Admin - Yes see http://www.comfortforums.com/forum105/3727.html - ident - 11-02-2011 If you look at the pictures of the KP06 with frame, the only part of the \"insert\" which is visible is a small border around the LCD and keyboard submodules. Having a black border on the modules with a surrounding white frame seems to me to be quite an attractive feature, if you look at the photos of the white and cream faceplates below. Comments from others welcome |
