Zone name not show in App - Printable Version
+--- Forum: iOS Apps (https://www.comfortforums.com/forum-122.html)
+---- Forum: Comfort iPhone App (1st generation) (https://www.comfortforums.com/forum-96.html)
+---- Thread: Zone name not show in App (/thread-2684.html)
Pages: 1 2
- ident - 04-24-2014
Yes  it should have been resolved by using the correct link
can you use the link https://www.cytech.biz/crl_comfort_app_convertor.php and try again
Are you still using iOS5? You should have converted to 6 at least as support for the old OS may not be there
- Guest - 04-25-2014
Hi Ident
I have tried the link you supplied above a couple of times but I am still not getting any zones being shown on the app.
I am using IOS version 7.1 with configurator version 3.8.6.0
Let me know if you need any further info.
- ident - 04-25-2014
can you send your cclx file to support@cytech.biz
- ident - 04-26-2014
Hi avney
we have looked at your file and the zones on the app
On your app we can see the zones
Your zones programming in your cclx is shown below
You can see that your zone names are exactly what you see on the app
The zone name is the \"Name\" field. The \"Phrase\" field are the 4 words that are announced in the keypad. These are not the same since the words used for announcement are limited while the Name field can be any text in any language
if you want to change the names shown on the app, then make the change on each zone name by editing on the right pane
- Guest - 04-26-2014
Thanks for the lesson Ident Smile. It became completely obvious as soon as you explained it. I have modified my config, and it worked fine after that.
Thanks again
Avney
