Ethernet Connectivity to third party devices - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Comments, Suggestions & Feedback (https://www.comfortforums.com/forum-22.html) +--- Thread: Ethernet Connectivity to third party devices (/thread-2826.html) Pages:
1
- admin - 04-13-2012 You are correct The current product have one predefined connection But the device may be able to programmed to open diffeernt connections. This would be a new functionality for the Universal, if the R&D is agree to do it - garym999 - 04-13-2012 Admin, your call, it is just a suggestion. But I think it should be a command available to the UCM/Ethernet as well as the UCM/Universal. This gives Comfort one way control via UCM/Ethernet and possibly 2-way via the UUCM. Of course that in turn involves new FW for the UCMs & Comfort + a support update for Comfigurator so I appreciate it is not an overnight request. If you take a step back and look at your logic engine with this type of connectivity you are not far of from having a control system along the lines of ControlFX (Command Fusion), BitwiseControls, AMX etc. Perhaps you should pole a selection of suggestions in order to prioritise them by need. - ident - 04-14-2012 Yes that seems a good suggestion. We shall consider if this can be implemented for UCMs - schford - 04-17-2012 +1 vote from me! - Home - 11-19-2013 Has any progress been made on this topic. We have IP commands working to Loxone but cannot as yet get loxone talking to comfort. I think this is certainly the way forward - an update of what is currently available and any examples or user experiances would always be useful. - ident - 11-20-2013 You can use Univeral UCM + ETHernet submodule to have 2 way communication to 3rd party products like Loxone. This is already available Gary suggestion is for 1 universal UCM to be able to talk to different devices at the same time which is not available, but it is not necessary for your requirement which is to have 2 way communications with Loxone |
