Comfigurator not updating time with UCM-ETH v.6.012 - Printable Version
+---- Forum: UCM/ETH01 & UCM/ETH02 (https://www.comfortforums.com/forum-119.html)
+----- Thread: Comfigurator not updating time with UCM-ETH v.6.012 (/thread-2872.html)
Pages: 1 2
- Ingo - 05-20-2012
I tested the exact same versions and mine works every time.
Ingo
- gaynorc - 05-20-2012
Have you two UCM_ETHs connected, one old 5.092 and one new 6.012?
- Ingo - 05-20-2012
Ok, I used 5.192 instead because I don\'t have a OTP version. I did your test from both UCM\'s and they both returned the correct time change. Before I forget, both my UCM\'s are ETH01\'s.
Ingo
Okay well the UCM_ETH v. 6.012 that I refer to is the ETH02 (silver)
- gaynorc - 05-23-2012
Firstly:
I tried disconnect UCM 5.92 and did the date test again.
The date did not update.
UCM I/O monitor - same output as above.
It seemed to take, but did not.
HOWEVER:
The problem is wider than I thought. I cannot upload cclx files. It tries to start, waits, 0% progress, and then gives the error \"error writing configuration: no response from UCM\".
In summary on my UCM-ETH v6.012:
I can download the log file.
I can reset the system
I can get system information
I cannot update date and time
I cannot write PC->Comfort
- slychiu - 05-23-2012
Were you able to write to Comfort before using the UCM/ETH 6.012 at all before? Or is this a new UCM that you have not used before. What were you using the UCM/ETH02 for before, was it for the iPhone app, and did that work with it?
can you send the screenshots of the DS Manager settings of the ETH02
Problem solved.
In October 2011 I updated the firmware on the Ethernet module (Tibbo Device) to the version suggested on the following link: http://www.comfortforums.com/forum96/2520-2.html
The purpose was to try and resolve iPhone ios5 connection problems. In that posting it was suggested as follows:
\"[Cytech] have not experienced this problem after upgrading to iOS5. This may be because we have been using a custom application on the EM500. This logs out the UCM when a connection has been lost for any reason. It also helps secure the system againts someone else connecting to the system after another connection has logged in. It allows a connection to connect only when the previous connection has logged out.\"
The firmware version was as follows: Attachment: cytech_application-3_02.zip (Downloaded 3 times)
See the discussion at: http://www.comfortforums.com/forum96/2520-2.html
Today I downloaded the version of firmware on your website: cytech_nowifi_3_10
Once I did that, the ETH worked fine.
(I hope!!)
Thanks for that
I have deleted the old attachment from the link
