KNX 6.024 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: KNX (EIB) (https://www.comfortforums.com/forum-12.html) +---- Forum: UCM/KNX Firmware (https://www.comfortforums.com/forum-89.html) +---- Thread: KNX 6.024 (/thread-3058.html) Pages:
1
- TheMax74 - 02-19-2013 I\' m still with 6.015 because the behaviour of 6.024 in handling telegrams has changed. Will the next firmware handle telegrams like 6.015? (See your post #6 in this thread) Thanks. - ident - 02-19-2013 Why do you prefer the old way, telegram with the same value is sent to Comfort? An explanation will help us to underrstand the concerns, as others prefer the new way It is not advisable to keep using old firmware for long because support will be a problem in future - TheMax74 - 02-19-2013 I have many scenes that work with only \"on\" telegram. I have all pushbuttons that works in the same way, only \"on\" telegram are sent, because those are, for example, secondary pushbuttons for garage door, timed lights etc. I boubt to be the only one and i think that others will have same problems. When passed from 6.015 to 6.024, it was a nightmare, so i reverted to 6.015. Telegrams must alway be passed because comfort is a central logic unit (and it has to trap all telegrams to correctly handke logic functions) and not a stupid light actuator. You may provide a checkbox to swith between behaviours, but i really think that not filtering is the correct way. Thanks - ident - 02-20-2013 Thanks, you may have a point Do anyy other users have a diffferent opinion? - gimi - 02-20-2013 Any idea when the \"KNX to Comfort for Keypad keys, Panic, Time, Date, Arm system, Bypass zone do not work\" bug is going to be solved? I am relaying on this functionality to arm/disarm the alarm and right now I cannot do it anymore which is annoying. Any work around while you are working on the fix? Cheers, GIMI - ident - 02-21-2013 It is fixed, see http://www.comfortforums.com/forum89/3291.html KNX6.111 and 6.112 available, please read the post to find the differences, related to the \"old way\" and the \"new way\" |
