Receiving a TCP message in Comfort - Printable Version
+--- Forum: Universal UCM (https://www.comfortforums.com/forum-94.html)
+--- Thread: Receiving a TCP message in Comfort (/thread-3387.html)
Pages: 1 2
- ident - 05-20-2013
There should be no problem for the Universal UCM to accept the message
We need to know all your settings on DS Manager and Universal UCM so we can see what you have done wrong
- Somersetdude - 05-20-2013
1st image
2nd image
3rd image
last image.
The only thing ive changed is the baud rate the max setting that matches is 38400 but ive tried it at others also.
- HeFeng - 05-20-2013
Hi,Somersetdude, see your UCM02 setting,you use header byte 03, I think you didn\'t send 03 to the Universal UCM , so you can\'t see anything,now change header bytes to be 0(means no header) and see any difference...
by the way, Eth02 plugged on the general UCM and universal UCM with different firmware, on general UCM, use cytech3_13.bin, on Universal UCM , use CytechUni3_13.bin...
Ok cheers, i\'ll try that. I\'m not back until later tonight to test.
I updated the firmwares at the weekend as per your information,
Tried changing the header to 0 but no change still not seeing anything.....
All working now!!!
Doh - jumper setting to add eth02 board...
Lots to do - now have cameras talking to comfort via TCP yippee.
