More than 8 Keypads - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Comments, Suggestions & Feedback (https://www.comfortforums.com/forum-22.html) +---- Forum: Wishlist (https://www.comfortforums.com/forum-66.html) +---- Thread: More than 8 Keypads (/thread-3575.html) Pages:
1
- Pharris14 - 05-16-2014 I am new to Comfort and I am building a test system and I have the same keypad problems as dcrera. I have two keypads in the system but it sees 15. I have tried the \"update defaults\" but the problem remains. - ident - 05-16-2014 did you restart comfigurator after updating defaults? - Pharris14 - 05-16-2014 Hi, yes, I updated the file then logged out of Comfigurator and logged back in again, Keypads 9 to 15 reappeared and keypad 8 shows a comms error. - dcrera - 05-16-2014 Hi Why can\'t we go back to 386 with a back up cclx file ? Why is it still showing version 387 on the flash screen ? Thanks - dcrera - 05-16-2014 Hi I think I got this. I manually deleted all but the keypads I require and downloaded from PC to Comfort. No comms issues thus far Thanks - Pharris14 - 05-16-2014 Excellent, I have just tried the same and it looks OK.Thanks to all for you help. - ident - 05-19-2014 This phantom keypad problem where keypads 9 to 16 appears as \"not polled\" occurs when Comfigurator 3.8.7 to 3.88 is used and Comfort has just reset. Upgrade to comfigurator 3.8.8, go to File > Update Defaults to update the default files to Comfigurator. This should fix the problem Also this is fixed in Firmware 7.057 |
