Comfort 2 5.054 Diallout - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: Comfort 2 5.054 Diallout (/thread-358.html) Pages:
1
- slychiu - 12-18-2006 The battery/Supplementary power supply is really a requirement for an intruder alarm system as the system would be very vulnerable without one. A power cut would disable the system. The main power supply is able to provide 1 Amp + to power all the devices. hence when you have a few speakers or sirens this exceeds the maximum load and requires the battery to help supply some of the current - rodime - 12-18-2006 Understood. But as stated above, the battery is connected and healthy - slychiu - 12-19-2006 Sorry missed what you said about battery connected The speaker output is specified as 8 ohms. If you connect two 8 ohms speakers the load becomes onyl 4 ohms. Yu can try connecting the speakers in series instead of parallel which means that the load is 16 ohms for 2 8 ohms speakers |
