S12V on SEP not breaking with aux off command - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: S12V on SEP not breaking with aux off command (/thread-361.html) Pages:
1
- slychiu - 01-21-2007 OK it is good to know that the problem waasa identified at least we will find what went faulty when we get it back and let you know Make sure you indicate the fault when you return the board - Home - 03-31-2007 I did send this pcb back to cytech - Nigel tells me that it is now back at his office - was the fault found? - ident - 04-01-2007 Its not in Singapore - must be with Nigel - Home - 04-01-2007 I do mark our returns have you no record of the SEP with S12V repair or are there several! - ident - 04-05-2007 Andy There is no such system with us for repair. They must be still in Cytech Europe being investigated regards |
