Comfigurator 3.7.7 / 3.78 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 3.x Old Versions (Archive) (https://www.comfortforums.com/forum-87.html) +---- Thread: Comfigurator 3.7.7 / 3.78 (/thread-3619.html) Pages:
1
- ident - 01-10-2014 The \"phantom Keypad\" is produced by the following conditions
![]() Transfer > Firmware Upgrades is for firmware upgrade by programmng cable for firmware < version 6 - ident - 01-11-2014 Update Right clicking on keypads will not show the options to upgrade firmware if the module after scanning is \"not found\" ie in red That means the scan was unable to detect the keypad, hence it would not be possible to upgrade its firmware. The KT03 was not found perhaps because its ID was set to FF ie unassigned. Older KT03 firmware may have a problem of having the ID reset to FF Upgrading to KT03 7.032 will probably fix this issue |
