UCM/Cbus2 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: CBus (https://www.comfortforums.com/forum-11.html) +--- Thread: UCM/Cbus2 (/thread-3755.html) |
- ident - 04-06-2014 Sending Commands to Cbus There are 2 ways to send commands to Cbus; the Direct and Indirect method Direct Commands to Cbus In Response Wizard, select UCM > Cbus2 ![]() ![]() The CBus Action window appears ![]() Select the application, eg 56 for Lighting Select the Group Address A dropdown list of C-Bus Lighting commands are shown ![]() Select the command If the command is to go through Remote Network Bridges enter the bridge numbers in the list separated by commas as shown ![]() ![]() Press OK to confirm the C-Bus Action You can add more Cbus actions to be sent to C-Bus in the same Response. Sequential C-Bus commands are concatenated together automatically. Indirect Commands to C-Bus Indirect commands can be sent to C-Bus by means of the Comfort Registers that are mapped to C-Bus Group addresses. This is a useful new feature in UCM/CBUS2 For example, if Lighting Group Address 5 is mapped to Counter 1, changing Counter 1 to 0 will switch off Lighting Group 5, changing Counter 1 to 255 will switch on Lighting group, and putting a value of 1 to 254 into the counter will dim the Group to the same level If a lighting Group is mapped to a Flag which has states on and off, then setting the flag will turn on the Lighting Group and clearing the flag will switch off the Lighting Group If a lighting group is linked to Output (but not Output Pulse or Output Toggle), then turning on the Output wiil turn on the Lighting Group and turning off the Output will switch off the Lighting Group - Home - 04-07-2014 Fantastic Cannot wait to try this out.... Can I purchase a CBUS2 now or do I have to purchase the 1 and then upgrade? As a cautionary note - the submodule - should this be the same numbering/lettering as the main board i.e. UCM/CBUS2CBUS2 daughter board (or sub board) - ident - 04-07-2014 You can purchase a UCM/CBUS1 and upgrade. The distributors will not have UCM/Cbus2 yet The submodule has its own part number CBUS01 - Howser - 04-07-2014 I upgraded my UCM/CBus1 today and played a bit with the Cbus2 features, so far it looks pretty cool. - Howser - 04-08-2014 I like the fact that the Lighting Tab, as well as Trigger and Enable have Group Address and Name displayed in the listed properties. It is possible to have the same in the Physical Inputs? - ident - 04-08-2014 Thanks, good suggestion. It will be implemented in a future version, nit the next 3.8.6 which is already beiing tested - ident - 04-11-2014 UCM/CBUS2 firmware 7.045 (Beta) can be downloaded from https://www.cytech.biz/ucmcbus2_firmware.html The changes are;
- ident - 04-11-2014 Comfigurator 3.8.6 Beta has the following changes for UCM/CBUS configuration. UCM/CBUS 2 firmware 7.045 should be used with this software version.
Known Bugs
- Howser - 04-12-2014 ident wrote: Quote:Comfigurator 3.8.6 Beta has the following changes for UCM/CBUS configuration. UCM/CBUS 2 firmware 7.045 should be used with this software version.The security Application is enabled when there is a PAC, right? - ident - 04-12-2014 I am not sure of the PAC If it worked with the old UCM/CBus on the security application, then it supports the security application |
