Comfort 2nd Generation Android App Version 1.4 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfort Android App (https://www.comfortforums.com/forum-110.html) +--- Thread: Comfort 2nd Generation Android App Version 1.4 (/thread-4197.html) |
- slychiu - 05-17-2015 We have generated a test which should work for Lollipop which you can download from https://www.cytech.biz/product_details.php?item_id=373 You can unzip the apk and install on your phone However you will have to uninstall the app before installing it and re-enter the data from the attachment, if you do not mind doing that - Swiss-Toni - 05-17-2015 I have exactly the same issues with a samsung S4 running 4.2.2 However I do like the direction that this App is now taking with all the custom-ability of it and appreciate the work that has gone into designing it. - wexfordman - 05-17-2015 [user=1]slychiu[/user] wrote: Quote:We have generated a test which should work for Lollipop Hi, I did that and exact same thing happening unfortunately] - juwi_uk - 05-17-2015 I\'m seeing another issue. I load in the new config and it works fine in the UI. But when I next restart the APP the config seems to have disappeared again and all I get is the CONTROL menu (empty) when I log in. Seems not to remember I\'ve added the config. Julian - slychiu - 05-18-2015 Those who cannot see the buttons in setup please send the cclx files to support@cytech.biz It is not a problem with Lollipop b ut it may be certain aspects oof the control menu - slychiu - 05-18-2015 [user=876]juwi_uk[/user] wrote: Quote:I load in the new config and it works fine in the UI. But when I next restart the APP the config seems to have disappeared again and all I get is the CONTROL menu (empty) when I log in.Could it be that you checked the button for Control Only? This hides the alarm pages - juwi_uk - 05-18-2015 Nope it\'s unchecked. - wexfordman - 05-18-2015 Hi, Sent my logfile as requested. Regards,Eamon - slychiu - 05-18-2015 We have tested your file There are a few problems with the control menu ![]() In the control actions, Comfort feedback expects key 0 to be OFF and 1 to be ON Yours is the reverse is 1 is OFF and 0 is OFF what you have done will give the wrong feedback If the counter value is 255 the status should be ON, and the system uses the text for key 1 which in your case is Office Light Off The keypad and phone voice menu works in the same way, 0 must be ON and 1 must be ON otherwise the status is reversed. This also coincides with a state of 0 and 1. People expect 0 state to be off and 1 state to be on,not the other way round The other problem is that for the symbols for off and on to work, the text in 0 and 1 should be Off and On respectively, not Kitchen Light Off and Kitchen Light on If the control key is Kitchen Light, then it is not necessary to again use text Kitchen Light Off and Kitchen Light ON, Off and On is sufficient The suggested order of the control menu is as below ![]() ![]() ![]() In your original program, the control menu wlll not show the icons for off and on, instead you will see the text for the feedback only ![]() In the revised format of 0 for off and 1 for on, the app will show as below Notice the Kitchen light has changed from text to icon. I did not reprogram Kitchen and family room etc ![]() - wexfordman - 05-18-2015 Brilliant Makes sense now, I will revise and upload ta new menu tonight. Thanks, Eamon |
