DST problem - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: DST problem (/thread-4425.html) Pages:
1
- slychiu - 04-02-2016 No need to send the evemt log. We managed to duplicate the problem as you reported - Guest - 04-02-2016 That\'s good. I look forward to the fix. In the meanwhile, I\'ve offset the timer that switches off my heating so it happens the other side of 1am. - slychiu - 04-04-2016 Please download ULT 7.097 (Beta) from https://www.cytech.biz/download_files.php?item_id=861 This should fix the problem for updating from 12 am to 1 AM - Guest - 04-04-2016 Thank you. I\'ll do that. - Guest - 04-05-2016 Mixed results with the new firmware. I\'m afraid I am still getting exactly the same issue with the time/date jumping backwards then forwards again between 12am and 1am. However, it does appears to have had a positive effect on the accuracy of the time in general. Prior to the firmware upgrade, every Date/Time Change was recorded in the event log. I believe such instances are only logged when the time is more than four seconds out. However, since the upgrade at 5pm yesterday such logged changes are rare outside of the 12am to 1am window when Comfort mistakenly thinks its time is an hour out. I\'m going to send you event log so you can see for yourself. Regards, Craig - slychiu - 04-07-2016 We believe we have fixed the problems with daylight saving time advancement from 2300 hours to midnight not working correctly Please upgrade to ULT 7.099 (Beta) from https://www.cytech.biz/download_files.php?item_id=863 - Guest - 04-07-2016 Thanks. I\'ll let you know what happens at the end of the day. - Guest - 04-08-2016 That appears to have fixed it. Thanks. - slychiu - 04-08-2016 Thanks for the confirmation. The other changes in the firmware will be revealed soon - slychiu - 04-27-2016 Firmware 7.099 which fixes this issue has been released See http://www.comfortforums.com/view_topic.php?id=4443&forum_id=79 |
