Partitions in Comfort - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Comfort Installation and Programming Guide (https://www.comfortforums.com/forum-124.html) +---- Forum: Security System Programming (https://www.comfortforums.com/forum-125.html) +---- Thread: Partitions in Comfort (/thread-4491.html) Pages:
1
- slychiu - 08-13-2016 Quote: if you arm the system in the partition it activates my electronic locks to lock (this was originally set up pre partitioning when activating alarm, in alarm responses).Alarm-related Responses need some consideration because partitions are involved It depends on what triggers the Response For example, if your Away Mode Response locks the door, then arming to away mode in any Partition will lock the door Comfigurator 3.11.6 has different Security Mode Responses for each partition ![]() If the Response is from Alarm Type Response eg System Armed then the Response will act on all partitions. To act on a specific Partition, you have to Set Partition number in the Alarm Response - Swiss-Toni - 08-13-2016 For some reason I saw that and overlooked it, School boy error. will correct it later, thanks for pointing that out, I know it must get tedious repeating yourself.... - slychiu - 09-11-2016 The Partitions feature has now been released in Firmware 7.113! see the case study on Partitions here http://www.comfortforums.com/forum16/4527.html - slychiu - 11-16-2016 There is a bug in Comfort firmware 7.113 if the firmware is upgraded from an older version some of the higher numbered unused zones may have nonzero partitions due to unused memory locations now having a meaning The effect of this is it causes a problem while arming if zones are open. The announcement and beeping on the keypads is interrupted and continuous and the system cannot arm. The keypad and Comfigurator cannot sign in until after 5 minutes, the Arming abort Time. The work-around if the system gets into this state is to wait for 5 minutes when the arming aborts. Then check the zones settings in Comfigurator make sure that all zones do not have Partititions>0 (provided this system does not use Partitions), and do a write to Comfort A new firmwware will be released shortly - slychiu - 11-17-2016 ULT 7.116 (currently beta) fixes this problem see http://www.comfortforums.com/view_topic.php?id=4559&forum_id=79 - slychiu - 03-28-2021 CM9001-EX with 8 Alarm Parttions and 99 Users is now available, see http://www.comfortforums.com/view_topic.php?id=5295&forum_id=125 - slychiu - 12-29-2021 New features for Partitions in Firmware 7.194
